Hier der Inhalt der Log:
2009-12-27 16:01:59,2, smsd: Smsd v3.1.6 started.
2009-12-27 16:01:59,2, smsd: Running as maex:None.
2009-12-27 16:01:59,7, smsd: Running startup_check (shell): /tmp/smsd_script.orEbot /tmp/smsd_data.KLNJW8
2009-12-27 16:01:59,7, smsd: Done: startup_check (shell), execution time 0 sec., status: 0 (0)
2009-12-27 16:01:59,4, smsd: File mode creation mask: 022 (0644, rw-r--r--).
2009-12-27 16:02:00,5, smsd: Outgoing file checker has started. PID: 3604.
2009-12-27 16:02:00,5, GSM1: Modem handler 0 has started. PID: 6068.
2009-12-27 16:02:00,3, GSM1: Cannot open serial port /dev/com1, error: No such file or directory
2009-12-27 16:02:00,2, GSM1: Modem handler 0 terminated. PID: 6068, was started 09-12-27 16:02:00.
2009-12-27 16:08:57,2, smsd: Smsd v3.1.6 started.
2009-12-27 16:08:57,2, smsd: Running as maex:None.
2009-12-27 16:08:57,7, smsd: Running startup_check (shell): /tmp/smsd_script.oJ4M7E /tmp/smsd_data.suFb5N
2009-12-27 16:08:58,7, smsd: Done: startup_check (shell), execution time 1 sec., status: 0 (0)
2009-12-27 16:08:58,4, smsd: File mode creation mask: 022 (0644, rw-r--r--).
2009-12-27 16:08:58,2, smsd: Running in terminal mode.
2009-12-27 16:08:58,5, smsd: Outgoing file checker has started. PID: 4864.
2009-12-27 16:08:58,5, GSM1: Modem handler 0 has started. PID: 2420.
2009-12-27 16:08:58,3, GSM1: Cannot open serial port /dev/com1, error: No such file or directory
2009-12-27 16:08:58,2, GSM1: Modem handler 0 terminated. PID: 2420, was started 09-12-27 16:08:58.
2009-12-27 16:09:00,3, smsd: FATAL ERROR: Looks like another smsd (4864) is running. I (3604) quit now.
2009-12-27 16:09:00,2, smsd: Smsd mainprocess terminated abnormally. PID: 3604.
2009-12-27 16:09:43,2, smsd: Smsd mainprocess is awaiting the termination of all modem handlers. PID: 4864.
2009-12-27 16:09:43,2, smsd: Smsd mainprocess terminated. PID 4864, was started 09-12-27 16:08:58.
