Der Fehler ist schon wieder aufgetreten, wobei es garkein Alarm für uns gab:
!ENTRY de.alamos.monitor.alarmcontributor 4 0 2014-01-17 23:27:46.132
!MESSAGE Fehler bei Konvertierung des Alarms aus FE
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:4397)
at org.eclipse.swt.SWT.error(SWT.java:4312)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Sync hronizer.java:196)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UI Synchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.j ava:4688)
at de.alamos.monitor.alarmcontributor.AlarmContributo r.contributeAlarm(AlarmContributor.java:301)
at de.alamos.monitor.alarmcontributor.AlarmContributo r.addAlarm(AlarmContributor.java:406)
at de.alamos.monitor.alarmcontributor.AlarmContributo r.access$3(AlarmContributor.java:346)
at de.alamos.monitor.alarmcontributor.AlarmContributo r$ReceiverThread.run(AlarmContributor.java:537)
Caused by: java.lang.NullPointerException
at de.alamos.monitor.perspectives.PerspectiveControll er.getIdForAlarm(PerspectiveController.java:245)
at de.alamos.monitor.perspectives.PerspectiveControll er.switchPerspective(PerspectiveController.java:19 8)
at de.alamos.monitor.perspectives.AlarmDataHandler.st artAlarmHandling(AlarmDataHandler.java:9)
at de.alamos.monitor.extensionpoint.AlarmDataReceiver .receiveAlarm(AlarmDataReceiver.java:14)
at de.alamos.monitor.alarmcontributor.AlarmContributo r$2.run(AlarmContributor.java:306)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableL ock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessa ges(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(D isplay.java:4145)
at org.eclipse.swt.widgets.Display.msgFilterProc(Disp lay.java:3477)
