Hallo...
ich kann mich nicht zu XMPP connecten. Sind Probleme bekannt?
Hallo...
der Log zeigt mir folgendes an: XMPP --- Verbindung zu Server konnte nicht hergestellt werden (XMPPError connecting to hermes6.jabber.org:5222.)
Und der Log:
21:21:03 [INFO] [XMPPThread Wed Aug 15 21:21:03 2012] [server.PluginController][75] PluginController mit Plugin xmpp.XMPP (Admin1) mit AlarmData ()wurde gestartet
21:21:03 [DEBUG] [XMPPThread Wed Aug 15 21:21:03 2012] [server.PluginController][288] Das GUIElement person-xmpp benötigt xmpp-Information der Person
21:21:03 [DEBUG] [XMPPThread Wed Aug 15 21:21:03 2012] [xmpp.XMPP][37] XMPP-Plugin gestartet
21:21:03 [DEBUG] [XMPPThread Wed Aug 15 21:21:03 2012] [xmpp.XMPP][42] Headline:
21:21:03 [DEBUG] [XMPPThread Wed Aug 15 21:21:03 2012] [xmpp.XMPP][44] Modus: Wichtige Nachricht
21:21:24 [ERROR] [XMPPThread Wed Aug 15 21:21:03 2012] [xmpp.XMPP][74] Verbindung zu Server konnte nicht hergestellt werden
XMPPError connecting to hermes.jabber.org:5222.: remote-server-error(502) XMPPError connecting to hermes.jabber.org:5222.
-- caused by: java.net.ConnectException: Connection timed out: connect
at org.jivesoftware.smack.XMPPConnection.connectUsing Configuration(XMPPConnection.java:524)
at org.jivesoftware.smack.XMPPConnection.connect(XMPP Connection.java:953)
at xmpp.XMPP.run(XMPP.java:60)
at server.PluginController.run(PluginController.java: 97)
at java.lang.Thread.run(Unknown Source)
Nested Exception:
at java.net.TwoStacksPlainSocketImpl.socketConnect(Na tive Method)
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.connectToAddress( Unknown Source)
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at org.jivesoftware.smack.proxy.DirectSocketFactory.c reateSocket(DirectSocketFactory.java:28)
at org.jivesoftware.smack.XMPPConnection.connectUsing Configuration(XMPPConnection.java:512)
21:21:24 [INFO] [XMPPThread Wed Aug 15 21:21:03 2012] [server.PluginController][140] PluginController mit Plugin xmpp.XMPP (Admin1) mit AlarmData () nach 20984 ms beendet
21:21:24 [DEBUG] [EAPipelineThread Wed Aug 15 21:21:02 2012] [server.Pipeline][210] PluginController xmpp.XMPP (Admin1) wird nach einem Fehler übersprungen
21:21:24 [DEBUG] [EAPipelineThread Wed Aug 15 21:21:02 2012] [server.Pipeline][283] Erstelle AlarmHistory
21:21:24 [DEBUG] [Thread-17] [server.gui.status.GStatusController$ServerThread][155] Neue Alarmierungen sind da
21:21:24 [DEBUG] [Thread-17] [server.gui.MainFrame][727] Aktualisierung der AlarmHistory gestartet
21:21:24 [DEBUG] [EAPipelineThread Wed Aug 15 21:21:02 2012] [server.Launcher][474] 1 Oberflächen wurden über neue Alarmierungen informiert
21:21:24 [INFO] [EAPipelineThread Wed Aug 15 21:21:02 2012] [server.Pipeline][309] Alarmabarbeitung beendet
21:21:24 [INFO] [EAPipelineThread Wed Aug 15 21:21:02 2012] [server.Pipeline][139] Pipeline von Feuerwehr (EA) wurde nach 22109 ms beendet, isError?: true
21:21:24 [DEBUG] [HistoryThread] [server.gui.MainFrameController][190] Füge Eintrag zu History hinzu
21:21:24 [DEBUG] [PipeControllerThread] [server.PipelineController][158] Server legt sich schlafen!
Geändert von Rudie (15.08.2012 um 22:23 Uhr)
Ja, Problem wurde schon gemeldet.
Wir werden untersuchen woran es liegt.
Gibt es eine Möglichkeit, dass mir das WALDBRAND Plugin immer zu einer bestimmten Uhrzeit (Beispiel 08:00) die aktuellen Waldbrand-Stufe zuschickt?
Zur Zeit gibt es anscheinend nur die Möglichkeit bei Änderungen der WB-Stufe.
Gruß Etienne
Wenn man das Intervall auf 24 Std stellt und den Server um 08:00 Uhr startet, müsste das doch funktionieren (auch wenn's nicht die feine Art ist) ?!
Geändert von florian_hsk (22.08.2012 um 13:22 Uhr)
Wäre eigentlich cool, wenn man das Layout vom Server Monitor ändern könnte.
Also beispielweise "Status" (sieht man ja durch die farbliche Hinterlegung) und den "Zeitstempel" ausblenden, dafür beispielsweise den Alarmtext anzeigen lassen.
Wäre eine genauerer Übersicht.
Oder geht das sogar schon und ich weiß nur nicht wie?'
Gruß Florian 1/23
