OK, die Berichte werden immer länger, Fehlermeldungen immer mehr. Was ist das alles?
Detail
Fehler
• 2013-01-20 17:37:06,404 ERROR (WetterInput.java:363) - Fehler im WetterwarnInputPlugin
• 2013-01-21 09:57:07,403 ERROR (WetterInput.java:363) - Fehler im WetterwarnInputPlugin
• 2013-01-21 15:57:07,646 ERROR (WetterInput.java:363) - Fehler im WetterwarnInputPlugin
• 2013-01-21 20:27:07,814 ERROR (WetterInput.java:363) - Fehler im WetterwarnInputPlugin
• 2013-01-22 15:17:08,367 ERROR (WetterInput.java:363) - Fehler im WetterwarnInputPlugin
error.log
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at javax.swing.plaf.synth.SynthTreeUI.paint(Unknown Source)
at javax.swing.plaf.synth.SynthTreeUI.update(Unknown Source)
at javax.swing.JComponent.paintComponent(Unknown Source)
at javax.swing.JComponent.paint(Unknown Source)
at javax.swing.JComponent.paintChildren(Unknown Source)
at javax.swing.JViewport.paint(Unknown Source)
at javax.swing.JComponent.paintToOffscreen(Unknown Source)
at javax.swing.BufferStrategyPaintManager.paint(Unkno wn Source)
at javax.swing.RepaintManager.paint(Unknown Source)
at javax.swing.JComponent._paintImmediately(Unknown Source)
at javax.swing.JComponent.paintImmediately(Unknown Source)
at javax.swing.RepaintManager.paintDirtyRegions(Unkno wn Source)
at javax.swing.RepaintManager.prePaintDirtyRegions(Un known Source)
at javax.swing.RepaintManager.access$700(Unknown Source)
at javax.swing.RepaintManager$ProcessingRunnable.run( Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$400(Unknown Source)
at java.awt.EventQueue$2.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.AccessControlContext$1.doIntersectio nPrivilege(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilter s(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(U nknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarch y(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Warnungen
• 2013-01-20 17:20:13,858 WARN (LoginController.java:122) - Falscher Login
• 2013-01-20 17:20:13,858 WARN (RemoteGUIClient.java:122) - Fehlerhafter Login fÃŒr Benutzer admin
• 2013-01-20 17:20:22,108 WARN (LoginController.java:122) - Falscher Login
• 2013-01-20 17:20:22,093 WARN (RemoteGUIClient.java:122) - Fehlerhafter Login fÃŒr Benutzer admin
• 2013-01-20 17:20:33,077 WARN (RemoteGUIClient.java:122) - Fehlerhafter Login fÃŒr Benutzer admin
• 2013-01-20 17:20:33,077 WARN (LoginController.java:122) - Falscher Login
• 2013-01-20 17:20:42,483 WARN (RemoteGUIClient.java:122) - Fehlerhafter Login fÃŒr Benutzer admin
• 2013-01-20 17:20:42,483 WARN (LoginController.java:122) - Falscher Login
• 2013-01-20 17:21:11,919 WARN (LoginController.java:122) - Falscher Login
• 2013-01-20 17:21:11,903 WARN (RemoteGUIClient.java:122) - Fehlerhafter Login fÃŒr Benutzer ffw
• 2013-01-20 17:21:37,278 WARN (RemoteGUIClient.java:122) - Fehlerhafter Login fÃŒr Benutzer admin
• 2013-01-20 17:21:37,278 WARN (LoginController.java:122) - Falscher Login
• 2013-01-20 22:23:58,235 WARN (Weatherrules.java:176) - Regel fehlgeschlagen. Nachfolgende Plugins werden blockiert:
• 2013-01-20 22:23:58,235 WARN (Weatherrules.java:177) - 'Wetterwarnung' gröÃer gleich 'Unwetterwarnung' >> Unwahr
• 2013-01-21 08:33:58,508 WARN (Weatherrules.java:176) - Regel fehlgeschlagen. Nachfolgende Plugins werden blockiert:
• 2013-01-21 08:33:58,508 WARN (Weatherrules.java:177) - 'Keine Wetterwarnung' gröÃer gleich 'Unwetterwarnung' >> Unwahr
• 2013-01-21 16:43:59,207 WARN (Weatherrules.java:176) - Regel fehlgeschlagen. Nachfolgende Plugins werden blockiert:
• 2013-01-21 16:43:59,207 WARN (Weatherrules.java:177) - 'Wetterwarnung' gröÃer gleich 'Unwetterwarnung' >> Unwahr
Nicht erreichbare Ports
Alle Ports erreichbar
Alarmierungen
