Hallo Nabend,
Also wie das Problem besteht weiterhin ... abe es so gemacht wie du es beschrieben hattest >foeder< doch hier kommt immer noch die meldung ....
07.02.2015 - 16:22:39.418 INFO SendMessageApagerIOS - Versende Push-Nachrichten...
07.02.2015 - 16:23:00.476 ERROR SendMessageApagerIOS - Fehler beim Push-Versand: Communication exception: java.net.ConnectException: Connection timed out: connect
javapns.communication.exceptions.CommunicationExce ption: Communication exception: java.net.ConnectException: Connection timed out: connect
at javapns.communication.ConnectionToAppleServer.getS SLSocket(ConnectionToAppleServer.java:158) ~[firEmergency.jar:na]
at javapns.notification.PushNotificationManager.initi alizeConnection(PushNotificationManager.java:106) ~[firEmergency.jar:na]
at javapns.notification.transmission.NotificationThre ad.runList(NotificationThread.java:217) ~[firEmergency.jar:na]
at javapns.notification.transmission.NotificationThre ad.run(NotificationThread.java:201) ~[firEmergency.jar:na]
at java.lang.Thread.run(Unknown Source) [na:1.8.0_31]
Caused by: java.net.ConnectException: Connection timed out: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method) ~[na:1.8.0_31]
at java.net.DualStackPlainSocketImpl.socketConnect(Un known Source) ~[na:1.8.0_31]
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source) ~[na:1.8.0_31]
at java.net.AbstractPlainSocketImpl.connectToAddress( Unknown Source) ~[na:1.8.0_31]
at java.net.AbstractPlainSocketImpl.connect(Unknown Source) ~[na:1.8.0_31]
at java.net.PlainSocketImpl.connect(Unknown Source) ~[na:1.8.0_31]
at java.net.SocksSocketImpl.connect(Unknown Source) ~[na:1.8.0_31]
at java.net.Socket.connect(Unknown Source) ~[na:1.8.0_31]
at sun.security.ssl.SSLSocketImpl.connect(Unknown Source) ~[na:1.8.0_31]
at sun.security.ssl.SSLSocketImpl.<init>(Unknown Source) ~[na:1.8.0_31]
at sun.security.ssl.SSLSocketFactoryImpl.createSocket (Unknown Source) ~[na:1.8.0_31]
at javapns.communication.ConnectionToAppleServer.getS SLSocket(ConnectionToAppleServer.java:155) ~[firEmergency.jar:na]
... 4 common frames omitted
07.02.2015 - 16:23:00.477 INFO PluginController - PluginController mit Plugin apagerIOS.ApagerIOS (Admin8) mit AlarmData () nach 21453 ms beendet
07.02.2015 - 16:23:00.583 INFO Pipeline - Alarmabarbeitung beendet///
Bitte um Hilfe ich verzweifel bald ... und eines noch sei dazu gesagt also die Push Nachrichten kommen bei den IOS handys komischerweise an es wird alarmiert nur giebt er aber trotz alledem die Error meldung heraus.
