Ergebnis 1 bis 15 von 19
Thema: Probleme mit IOS
    Probleme mit IOS
    Hallo Community;
    Bekomme seit neusten diese fehelermeldung...
    3.02.2015 - 14:31:46.034 ERROR SendMessageApagerIOS - Fehler beim Push-Versand: Communication exception: java.net.ConnectException: Connection timed out: connect
    javapns.communication.exceptions.CommunicationExce ption: Communication exception: java.net.ConnectException: Connection timed out: connect
    at javapns.communication.ConnectionToAppleServer.getS SLSocket(ConnectionToAppleServer.java:158) ~[firEmergency.jar:na]
    at javapns.notification.PushNotificationManager.initi alizeConnection(PushNotificationManager.java:106) ~[firEmergency.jar:na]
    at javapns.notification.transmission.NotificationThre ad.runList(NotificationThread.java:217) ~[firEmergency.jar:na]
    at javapns.notification.transmission.NotificationThre ad.run(NotificationThread.java:201) ~[firEmergency.jar:na]
    at java.lang.Thread.run(Unknown Source) [na:1.8.0_31]
    Caused by: java.net.ConnectException: Connection timed out: connect
    at java.net.DualStackPlainSocketImpl.connect0(Native Method) ~[na:1.8.0_31]
    at java.net.DualStackPlainSocketImpl.socketConnect(Un known Source) ~[na:1.8.0_31]
    at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source) ~[na:1.8.0_31]
    at java.net.AbstractPlainSocketImpl.connectToAddress( Unknown Source) ~[na:1.8.0_31]
    at java.net.AbstractPlainSocketImpl.connect(Unknown Source) ~[na:1.8.0_31]
    at java.net.PlainSocketImpl.connect(Unknown Source) ~[na:1.8.0_31]
    at java.net.SocksSocketImpl.connect(Unknown Source) ~[na:1.8.0_31]
    at java.net.Socket.connect(Unknown Source) ~[na:1.8.0_31]
    at sun.security.ssl.SSLSocketImpl.connect(Unknown Source) ~[na:1.8.0_31]
    at sun.security.ssl.SSLSocketImpl.<init>(Unknown Source) ~[na:1.8.0_31]
    at sun.security.ssl.SSLSocketFactoryImpl.createSocket (Unknown Source) ~[na:1.8.0_31]
    at javapns.communication.ConnectionToAppleServer.getS SLSocket(ConnectionToAppleServer.java:155) ~[firEmergency.jar:na]
    ... 4 common frames omitted
    --aPager-iOS --- Fehler beim Push-Versand: Communication exception: java.net.ConnectException: Connection timed out: connect
    was kann das sein hatte vorher keine probleme gehabt und die alarmierung kommt komischerweise auch auf dem Telefon an.
    ---Und seit Heute wenn ich meine Rückmeldung abgeben will kommt jetzt wie bei IOS und Androit fehlermeldungen
    Mfg Henry
Hits:	270
Größe:	461,2 KB
    Der Fehler bei der Rückmeldung hat mit der Umstellung auf die Onlineservices zu tun. Den müsst ihr haben und die entsprechenden keys in fe und apager hinterlegen.
    Ja ok das ist denn schon mal eine sache die gelöst ist ... habe den onlineservice schon gebucht und warte nur darauf das mir mein daten zugeschickt werden...
    Bleibt immer noch problem numero 1.
    Wenn ich das richtig verstanden habe ist es derzeit noch nicht möglich über IOS die Rückmeldung abzugeben, da die API Schlüssel nirgendwo hinterlegt werden kann.
    Ist dem so? Kann man über iOS tatsächlich keine Rückmeldungen geben? Vielleicht können die Entwickler sich ja einmal dazu äußern?
    Doch, das geht nach wie vor. Nur Verfügbarkeit geht noch nicht. Vor kurzem gab es ein allgemeines Problem mit dem iOS Push. Hast du die aktuelle FE Version installiert? Wenn nicht, wird es wohl danach behoben sein.
    Hallo ja habe die Aktuelle Version instaliert ... nagut ich werde es weiterhin beobachten ob der fehler weiterhin auftauchen tut.
    bei mir wird bei der Rückmeldung IOS angezeigt: Fehler - Status konnte nicht geändert werden.
    Seriennummer wurde in FE unter Online Service eingetragen. Muss die Rückmeldefuntkion an sich in FE neu erstellt werden?
    Also ich habe immer noch das Problem mit IOS Push
    ---> aPager-iOS --- Fehler beim Push-Versand: Communication exception: java.net.ConnectException: Connection timed out: connect
    dieses bekomme ich ausgegeben woran liegt es ???
    feodor Gast
    Ggf. Firewall, Proxy aktiv?
    Internetverbindungsprobleme? Wie seid ihr angebunden?
    Wir sind über einen router von Vodafone angeschlossen bei uns in der wache ...
    entschuldige wenn ich hier jetzt solche fragen stelle aber was meinst du mit der Firewall , Proxy .... also es lief ja auch tadellos bis zum gestrigen tag da fingen auf einmal die Meldungen an das komische daran ist ja die Einsatzmeldungen so wie meine Testmeldungen kommen bei dem IOS Handy´s an nur halt ebend nicht als push also er giebt weder einen ton von sich oder zeigt diesen Alarm im ruhezustand/Sperrbildschirm an ...
    Also wenn ich den Server starte:
    4.02.2015 - 11:33:29.204 INFO UserManagement - Benutzer mit eingeschränkten Rechten dürfen KEINEN manuellen Alarm ausführen
    04.02.2015 - 11:33:29.207 INFO RXTXInstaller - Ermitteltes Betriebssystem: windows 7, x86
    04.02.2015 - 11:33:29.208 INFO RXTXInstaller - Kopieren von: C:\Program Files\Alamos UG\firEmergency\files\rxtx\rxtx_win32\RXTXcomm.jar nach: C:\Program Files\Java\jre1.8.0_31\lib\ext\RXTXcomm.jar nicht möglich
    Und das hier kommt im LOG wenn er einen Alarm raus schiken tut..
    04.02.2015 - 11:00:19.684 INFO SendMessageApagerIOS - Versende Push-Nachrichten...
    04.02.2015 - 11:00:40.735 ERROR SendMessageApagerIOS - Fehler beim Push-Versand: Communication exception: java.net.ConnectException: Connection timed out: connect
    04.02.2015 - 11:00:40.735 INFO PluginController - PluginController mit Plugin apagerIOS.ApagerIOS (Admin4) mit AlarmData () nach 21632 ms beendet
    04.02.2015 - 11:00:40.860 INFO Pipeline - Alarmabarbeitung beendet
    04.02.2015 - 11:00:40.860 INFO Pipeline - Pipeline von Einheit (wetter) wurde nach 22066 ms beendet. Fehler aufgetreten: Ja
    Ich hoffe ich konnte dir hier jetzt ein wenig das Problem näher bringen
    Mfg Henry
