So das wäre die Logdatei mit Loglevel Debug:
2011-10-08 11:04:22,2, smsd: Smsd v3.1.14 started.
2011-10-08 11:04:22,2, smsd: Running as Sebastian:None.
2011-10-08 11:04:22,7, smsd: Running startup_check (shell): /var/spool/sms/incoming/smsd_script.CwjCNE /tmp/smsd_data.yTEu4B
2011-10-08 11:04:23,7, smsd: Done: startup_check (shell), execution time 1 sec., status: 0 (0)
2011-10-08 11:04:23,4, smsd: File mode creation mask: 022 (0644, rw-r--r--).
2011-10-08 11:04:23,2, smsd: Running in terminal mode.
2011-10-08 11:04:23,5, smsd: Outgoing file checker has started. PID: 2928.
2011-10-08 11:04:23,7, smsd: All PID's: 2928,4356
2011-10-08 11:04:23,5, GSM1: Modem handler 0 has started. PID: 4356.
2011-10-08 11:04:23,3, GSM1: Couldn't open serial port /dev/COM4, error: No such file or directory, waiting 30 sec.
2011-10-08 11:04:24,5, smsd: Moved file /var/spool/sms/outgoing/Test.txt to /var/spool/sms/checked
2011-10-08 11:04:53,3, GSM1: Cannot open serial port /dev/COM4, error: No such file or directory
2011-10-08 11:04:53,2, GSM1: Modem handler 0 terminated. PID: 4356, was started 11-10-08 11:04:23.
2011-10-08 11:04:54,2, smsd: Smsd mainprocess is awaiting the termination of all modem handlers. PID: 2928.
2011-10-08 11:04:54,2, smsd: Smsd mainprocess terminated. PID 2928, was started 11-10-08 11:04:23.
