Moin Forum,
nachdem ich bislang den monitord nur unter Windows getestet habe, wollte ich ihn nun natürlich auch mal auf meinem frisch installierten Debian Lenny installieren.
1.) Tarball gezogen und entpackt - OK
2.) ./configure laufen gelassen - OK
3.) make gestartet - Fehler
Meldung hier wie folgt:
Ein zweiter Aufruf von make produziert dann Folgendes:Code:cd . && /bin/sh /root/trunk/missing --run aclocal-1.10 cd . && /bin/sh /root/trunk/missing --run automake-1.10 --foreign cd . && /bin/sh /root/trunk/missing --run autoconf configure.ac:38: error: possibly undefined macro: AM_PATH_ALSA If this token and others are legitimate, please use m4_pattern_allow. See the Autoconf documentation. make: *** [configure] Fehler 1
Was läuft hier nicht rund?Code:/bin/sh ./config.status --recheck running CONFIG_SHELL=/bin/sh /bin/sh ./configure --no-create --no-recursion checking build system type... i686-pc-linux-gnu checking host system type... i686-pc-linux-gnu checking target system type... i686-pc-linux-gnu checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... /bin/mkdir -p checking for gawk... no checking for mawk... mawk checking whether make sets $(MAKE)... yes checking for gcc... gcc checking for C compiler default output file name... a.out checking whether the C compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ISO C89... none needed checking for style of include used by make... GNU checking dependency style of gcc... gcc3 checking for g++... g++ checking whether we are using the GNU C++ compiler... yes checking whether g++ accepts -g... yes checking dependency style of g++... gcc3 ./configure: line 4167: syntax error near unexpected token `0.9.1,' ./configure: line 4167: ` AM_PATH_ALSA(0.9.1, HAVE_ALSA=yes, HAVE_ALSA=no)' make: *** [config.status] Fehler 2
Wer kann mir Tipps geben?
Danke und Gruß,
Funkwart
