Ich erlaube mir mal den dementprechenden Auszug aus der "unixinout.c" zu entnehmen.
Starten tut die Aufnahme ohne Probleme. Erst beim beenden der Aufnahme spricht er fehler aus. Letzter Fehler war bei mir irgendwas mit den Effekten. Kein Plan was genau.
void input_sound(unsigned int sample_rate, const char *ifname) {
* Audio-Device abfragen
int sndparam;
int fd;
/* verdoppelt für 2-Kanal */
union {
short s[8192 * CHANNELS];
unsigned char b[8192 * CHANNELS];
} b;
float fbuf[CHANNELS][16384];
unsigned int fbuf_cnt = 0;
int i;
short *sp;
unsigned char *bp;
int fmt = 0;
/* gfgf ==> */
time_t tp;
int rec_n, n;
void *rec_p;
if ((fd = open(ifname ? ifname : "/dev/dsp", O_RDONLY)) < 0) {
perror("open");
exit(10);
sndparam = AFMT_S16_LE; /* we want 16 bits/sample signed */
/* little endian; works only on little endian systems! */
if (ioctl(fd, SNDCTL_DSP_SETFMT, &sndparam) == -1) {
perror("ioctl: SNDCTL_DSP_SETFMT");
exit(10);
if (sndparam != AFMT_S16_LE) {
fmt = 1;
sndparam = AFMT_U8;
exit(10);
if (sndparam != AFMT_U8) {
exit(10);
sndparam = 1; /* 2 Kanäle */
if (ioctl(fd, SNDCTL_DSP_STEREO, &sndparam) == -1) {
perror("ioctl: SNDCTL_DSP_STEREO");
exit(10);
if (sndparam != 1) {
/* Monovariante? */
fprintf(stderr, "soundif: Error, cannot set the channel "
"number to 2\n");
exit(10);
sndparam = sample_rate;
if (ioctl(fd, SNDCTL_DSP_SPEED, &sndparam) == -1) {
// perror("ioctl: SNDCTL_DSP_SPEED");exit(10);
if ((10 * abs(sndparam - sample_rate)) > sample_rate) {
if (sndparam != sample_rate) {
fprintf(stderr, "Warning: Sampling rate is %u, "
"requested %u\n", sndparam, sample_rate);
#if 0
sndparam = 4;
if (ioctl(fd, SOUND_PCM_SUBDIVIDE, &sndparam) == -1) {
perror("ioctl: SOUND_PCM_SUBDIVIDE");
if (sndparam != 4) {
#endif
for (;;) {
channel = 0;
if (fmt) {
i = read(fd, bp = b.b, sizeof(b.b));
if (i < 0 && errno != EAGAIN) {
perror("read");
exit(4);
if (!i)
break;
if (i > 0) {
if (rec.stat) {
time(&tp);
if (tp > rec.start + rec.time)
record_stop();
else {
verbprintf(3, "Aufzeichung Kanal %c %i sec", _channel[channel], tp - rec.start);
sprintf(rec.in_args, "-u -b -r %d -c 2 -t raw", sample_rate);
rec_n = i;
rec_p = (void *) bp;
while (rec_n) {
n = write(rec.fd, rec_p, rec_n);
rec_n -= n;
rec_p += rec_n;
for (; i >= sizeof(b.b[0]); i -= sizeof(b.b[0] * 2), bp++) {
fbuf[0][fbuf_cnt] = ((int)(*bp++) - 0x80) * (1.0 / 128.0);
fbuf[1][fbuf_cnt++] = ((int)(*bp) - 0x80) * (1.0 / 128.0);
if (i)
fprintf(stderr, "warning: noninteger number of samples read\n");
if (fbuf_cnt > overlap) {
process_buffer(fbuf[0], fbuf_cnt - overlap);
memmove(fbuf[0], fbuf[0] + fbuf_cnt - overlap, overlap * sizeof(fbuf[0][0]));
channel++;
process_buffer(fbuf[1], fbuf_cnt - overlap);
memmove(fbuf[1], fbuf[1] + fbuf_cnt - overlap, overlap * sizeof(fbuf[1][0]));
fbuf_cnt = overlap;
else {
#ifdef ZLOG
char outprint[ITEMLEN];
#endif
i = read(fd, sp = b.s, sizeof(b.s));
/* Schliessen des Sounddevices und neustarten */
close(fd);
return;
#ifdef ZLOG
update_file("newbuf", LOG);
#endif
if (!i) break;
if (i > 0) {
if (rec.stat) {
time(&tp);
record_stop();
else {
sprintf(rec.in_args, "-e single-integer -2 -r %d -c 2 -t raw", sample_rate);
rec_n = i;
rec_p = (void *) sp;
while(rec_n) {
rec_n -= n;
rec_p += rec_n;
for (; i >= sizeof(b.s[0]); i -= sizeof(b.s[0]) * 2, sp++) {
fbuf[0][fbuf_cnt] = (*sp++) * (1.0 / 32768.0);
fbuf[1][fbuf_cnt++] = (*sp) * (1.0 / 32768.0);
#ifdef ZLOG
memset(outprint, 0, sizeof(outprint));
sprintf(outprint, "fbuf[%d]\t\t[li]%8.5f\t\t[re]%8.5f", fbuf_cnt-1, fbuf[0][fbuf_cnt-1], fbuf[1][fbuf_cnt-1]);
update_file(outprint, LOG);
#endif
if (i)
channel++;
fbuf_cnt = overlap;
close(fd);
#endif /* SUN_AUDIO */
void record_start (short *code) {
* Audio-Aufzeichung starten
char cmdline[LINELEN], buf[5];
struct tm *today;
int i = 0;
time(&tp);
if(!rec.stat) {
memmove(buf, code, 5);
today = localtime(&tp);
strftime(cmdline, 17, "%Y-%m-%d_%H%M", today);
sprintf(rec.file, "%s/%s_", rec.path, cmdline);
while(i < 5)
sprintf(rec.file, "%s%i", rec.file, code[i++]);
if((rec.fd = open(rec.file, O_WRONLY | O_CREAT | O_TRUNC, 0664)) < 0) {
fprintf(stderr, "Cannot open %s\n", rec.file);
rec.chan = _channel[channel] + ' ';
rec.stat = 1;
verbprintf(2, "Aufzeichung Kanal %c", _channel[channel]);
else
verbprintf(2, "Aufzeichung Kanal %c verlängert", _channel[channel]);
rec.start = tp;
} /* record_start
void record_stop (void) {
* Audio-Aufzeichung abschließen
char cmdline[256];
close(rec.fd);
rec.stat = 0;
sprintf(cmdline, "%s -v%f %s %s %s %s%s -%c", rec.cmd, (float)rec.volume / 100, rec.in_args, rec.file,
rec.out_args, rec.file, rec.suff, rec.chan);
system(cmdline);
sprintf(cmdline, "rm %s", rec.file);
system(cmdline);
verbprintf(2, "Aufzeichung Kanal %c beendet", _channel[channel]);
} /* record_stop
Original hier: http://grohmann.gmxhome.de/mon/monitor-1.8.1.tar.gz
