void input_sound(unsigned int	sample_rate, const char *ifname) {
 *	Audio-Device abfragen
int sndparam;
int fd;
/*	verdoppelt für 2-Kanal	*/
union {
	short s[8192 * CHANNELS];
	unsigned char b[8192 * CHANNELS];
} b;
float fbuf[CHANNELS][16384];
unsigned int fbuf_cnt = 0;
int i;
short *sp;
unsigned char *bp;
int fmt = 0;
/* gfgf ==> */
time_t tp;
int rec_n, n;
void *rec_p;
	if ((fd = open(ifname ? ifname : "/dev/dsp", O_RDONLY)) < 0) {
		perror("open");
		exit(10);
	sndparam = AFMT_S16_LE; /* we want 16 bits/sample signed */
	/* little endian; works only on little endian systems! */
	if (ioctl(fd, SNDCTL_DSP_SETFMT, &sndparam) == -1) {
		perror("ioctl: SNDCTL_DSP_SETFMT");
		exit(10);
	if (sndparam != AFMT_S16_LE) {
		fmt = 1;
		sndparam = AFMT_U8;
			exit(10);
		if (sndparam != AFMT_U8) {
			exit(10);
	sndparam = 1;   /* 2 Kanäle */
	if (ioctl(fd, SNDCTL_DSP_STEREO, &sndparam) == -1) {
		perror("ioctl: SNDCTL_DSP_STEREO");
		exit(10);
	if (sndparam != 1) {
		/*	Monovariante?	*/
		fprintf(stderr, "soundif: Error, cannot set the channel "
			"number to 2\n");
		exit(10);
	sndparam = sample_rate;
	if (ioctl(fd, SNDCTL_DSP_SPEED, &sndparam) == -1) {
//		perror("ioctl: SNDCTL_DSP_SPEED");exit(10);
	if ((10 * abs(sndparam - sample_rate)) > sample_rate) {
	if (sndparam != sample_rate) {
		fprintf(stderr, "Warning: Sampling rate is %u, "
			"requested %u\n", sndparam, sample_rate);
#if 0
	sndparam = 4;
	if (ioctl(fd, SOUND_PCM_SUBDIVIDE, &sndparam) == -1) {
		perror("ioctl: SOUND_PCM_SUBDIVIDE");
	if (sndparam != 4) {
#endif
	for (;;) {
		channel = 0;
		if (fmt) {
			i = read(fd, bp = b.b, sizeof(b.b));
			if (i < 0 && errno != EAGAIN) {
				perror("read");
				exit(4);
			if (!i)
				break;
			if (i > 0) {
				if (rec.stat) {
					time(&tp);
					if (tp > rec.start + rec.time)
						record_stop();
					else {
						verbprintf(3, "Aufzeichung Kanal %c %i sec", _channel[channel], tp - rec.start);
						sprintf(rec.in_args, "-u -b -r %d -c 2 -t raw", sample_rate);
						rec_n = i;
						rec_p = (void *) bp;
						while (rec_n) {
							n = write(rec.fd, rec_p, rec_n);
							rec_n -= n;
							rec_p += rec_n;
				for (; i >= sizeof(b.b[0]); i -= sizeof(b.b[0] * 2), bp++) {
					fbuf[0][fbuf_cnt] = ((int)(*bp++) - 0x80) * (1.0 / 128.0);
					fbuf[1][fbuf_cnt++] = ((int)(*bp) - 0x80) * (1.0 / 128.0);
				if (i)
					fprintf(stderr, "warning: noninteger number of samples read\n");
				if (fbuf_cnt > overlap) {
					process_buffer(fbuf[0], fbuf_cnt - overlap);
					memmove(fbuf[0], fbuf[0] + fbuf_cnt - overlap, overlap * sizeof(fbuf[0][0]));
					channel++;
					process_buffer(fbuf[1], fbuf_cnt - overlap);
					memmove(fbuf[1], fbuf[1] + fbuf_cnt - overlap, overlap * sizeof(fbuf[1][0]));
					fbuf_cnt = overlap;
		else {
#ifdef ZLOG
char	outprint[ITEMLEN];
#endif
			i = read(fd, sp = b.s, sizeof(b.s));
				/*	Schliessen des Sounddevices und neustarten	*/
				close(fd);
				return;
#ifdef ZLOG
update_file("newbuf", LOG);
#endif
			if (!i) break;
			if (i > 0) {
				if (rec.stat) {
					time(&tp);
				  	record_stop();
					else {
				    sprintf(rec.in_args, "-e single-integer -2 -r %d -c 2 -t raw", sample_rate);
				    rec_n = i;
						rec_p = (void *) sp;
						while(rec_n) {
							rec_n -= n;
							rec_p += rec_n;
				for (; i >= sizeof(b.s[0]); i -= sizeof(b.s[0]) * 2, sp++) {
					fbuf[0][fbuf_cnt] = (*sp++) * (1.0 / 32768.0);
					fbuf[1][fbuf_cnt++] = (*sp) * (1.0 / 32768.0);
#ifdef ZLOG
memset(outprint, 0, sizeof(outprint));
sprintf(outprint, "fbuf[%d]\t\t[li]%8.5f\t\t[re]%8.5f", fbuf_cnt-1, fbuf[0][fbuf_cnt-1], fbuf[1][fbuf_cnt-1]);
update_file(outprint, LOG);
#endif
				if (i)
					channel++;
					fbuf_cnt = overlap;
	close(fd);
#endif /* SUN_AUDIO */
void record_start (short *code) {
 *	Audio-Aufzeichung starten
  char cmdline[LINELEN], buf[5];
  struct tm *today;
	int i = 0;
  time(&tp);
	if(!rec.stat) {
		memmove(buf, code, 5);
  	today = localtime(&tp);
	  strftime(cmdline, 17, "%Y-%m-%d_%H%M", today);
	  sprintf(rec.file, "%s/%s_", rec.path, cmdline);
		while(i < 5)
		  sprintf(rec.file, "%s%i", rec.file, code[i++]);
	  if((rec.fd = open(rec.file, O_WRONLY | O_CREAT | O_TRUNC, 0664)) < 0) {
	    fprintf(stderr, "Cannot open %s\n", rec.file);
		rec.chan = _channel[channel] + ' ';
	  rec.stat = 1;
		verbprintf(2, "Aufzeichung Kanal %c", _channel[channel]);
	else
		verbprintf(2, "Aufzeichung Kanal %c verlängert", _channel[channel]);
	rec.start = tp;
} /* record_start
void record_stop (void) {
 *	Audio-Aufzeichung abschließen
  char cmdline[256];
  close(rec.fd);
  rec.stat = 0;
  sprintf(cmdline, "%s -v%f %s %s %s %s%s -%c", rec.cmd, (float)rec.volume / 100, rec.in_args, rec.file,
  			rec.out_args, rec.file, rec.suff, rec.chan);
  system(cmdline);
  sprintf(cmdline, "rm %s", rec.file);
  system(cmdline);
	verbprintf(2, "Aufzeichung Kanal %c beendet", _channel[channel]);
} /* record_stop
