Jetzt ging es... :
Also hier die Fehlermeldung:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidOperationException: An error occurred creating the form. See Exception.InnerException for details. The error is: Klasse nicht registriert (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)) ---> System.Runtime.InteropServices.COMException (0x80040154): Klasse nicht registriert (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
at System.Windows.Forms.UnsafeNativeMethods.CoCreateI nstance(Guid& clsid, Object punkOuter, Int32 context, Guid& iid)
at System.Windows.Forms.AxHost.CreateWithoutLicense(G uid clsid)
at System.Windows.Forms.AxHost.CreateWithLicense(Stri ng license, Guid clsid)
at System.Windows.Forms.AxHost.CreateInstanceCore(Gui d clsid)
at System.Windows.Forms.AxHost.CreateInstance()
at System.Windows.Forms.AxHost.GetOcxCreate()
at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
at System.Windows.Forms.AxHost.CreateHandle()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.AxHost.EndInit()
at Wetterwarnung.Infofenster.InitializeComponent()
at Wetterwarnung.Infofenster..ctor()
--- End of inner exception stack trace ---
at Wetterwarnung.My.MyProject.MyForms.Create__Instanc e__[T](T Instance)
at Wetterwarnung.My.MyProject.MyForms.get_Infofenster ()
at Wetterwarnung.Hauptfenster.aktualisieren()
at Wetterwarnung.Hauptfenster.Timeraktualisieren_Tick (Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndPr oc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
Wetterwarnung
Assembly Version: 0.0.0.36
Win32 Version: 0.0.0.2
CodeBase: file:///C:/Program%20Files%20(x86)/Wetterwarnung/Wetterwarnung.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Geändert von Glubschi (05.12.2008 um 11:48 Uhr)
@ Blinky,
die Fehlermeldung kam erst, als Wetterwarung das letzte Update gezogen hat.....
Wenn der Fehler nochmal auftreten sollen, kannste Dich ja nochmal melden.
Blinky
Der kommt sobald ich das Programm geöffnet habe....
Kommt..., geht wieder automatisch weg..., kommt..., ...... und immer so weiter....
Hab auch schon deinstalliert und wieder neu installiert. Das gleiche Problem.
Sieht so aus, das was bei Dir fehlt mhh
Aber das ging ja vorher auch alles, beim letzten Update von Wetterwarnung war Feierabend....
Schon komisch....
Schon mal versucht Setup von Hand zu installieren? Vielleicht ist beim Updaten was schief gelaufen bei Dir.
Starte mal dein Rechner neu und installiere mal von Hand. Wenn dann es immer noch nicht geht, dann ist da irgendwo der Wurm drinn.
Blinky
ich benutze Wetterwarung über einen Proxyserver und das funktioniert auch prima. Seit ein paar Wochen kommt folgende Fehlermeldung, sobald keine Internetverbindung verfügbar ist.
Code:See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.IO.FileNotFoundException: C:\Program Files\Wetterwarnung\KarteOffline.png at System.Drawing.Image.FromFile(String filename, Boolean useEmbeddedColorManagement) at System.Drawing.Image.FromFile(String filename) at Wetterwarnung.Hauptfenster.Kartenoffline() at Wetterwarnung.Hauptfenster.Kartenanzeigen_Tick(Object sender, EventArgs e) at System.Windows.Forms.Timer.OnTick(EventArgs e) at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- Wetterwarnung Assembly Version: 0.0.0.36 Win32 Version: 0.0.0.2 CodeBase: file:///C:/Program%20Files/Wetterwarnung/Wetterwarnung.exe ---------------------------------------- Microsoft.VisualBasic Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Runtime.Remoting Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- Microsoft.mshtml Assembly Version: 7.0.3300.0 Win32 Version: 7.0.3300.0 CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll ---------------------------------------- AxInterop.WMPLib Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Program%20Files/Wetterwarnung/AxInterop.WMPLib.DLL ---------------------------------------- Interop.WMPLib Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Program%20Files/Wetterwarnung/Interop.WMPLib.DLL ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example:When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
Kann man schon was sagen?
Fehlt bei Dir die Datei
Blinky
Wie war, wie war - eigentlich hätte ich da ja selber mal schauen können, wobei ich unterbewusst davon ausgegangen bin, dass dies auch so eine automatisch erstellte Karte ist. - Neu installiert und die Datei ist wieder da, wo sie hingehört.
Naja, da frag ich mich jetzt nur, wieso die Datei seit ein paar Tagen fehlt - außer den Updates mache ich eigentlich überhaupt nix dran...
Wo wir gleich bei dem Thema "Update" wären :-) da fällt mir grad auch noch was auf:
Bis gerade eben hatte ich keine Meldung, dass eine neue Version vorhanden ist. Nun habe ich die EXE aus deiner Signatur gezogen (damit ich die Datei "KarteOffline.png" wieder bekomme) und installiert und jetzt steht da "neue Version vorhanden" Selbst wenn ich dort auf "Update laden" klicke und das Update mache kommt die Meldung trotzdem. - Warum dies?
Gruß wave_ceptor
Be mir zeigt er nicht an Update vorhanden.
Es wird nur beim Programmstart nach Updates gesucht oder wenn man über das Menu auswählt nach Updates suchen.
Allerdings kommt es zu Fehlinfos, wenn der Server nicht erreichbar ist. Da dann die aktuelle Version als 0 interpretiert wird.
Blinky
Ich werde mal schauen, wie es sich morgen nach dem (Re-)Boot verhält...
also die Meldung erscheint auch nach einem Re-Boot noch, habe heute die manuelle sowie Update-Installation nochmal gemacht - keine Änderung. Gibt es eine Möglichkeit auszulesen, welche (wirkliche) Version installiert ist? (Vielleicht könntest du ja irgendwo, unabhängig von .NET, eine EIGENE Versionsnummer mit einarbeiten).
Ich möchte nicht ausschließen, dass ich wegen Firewall / Proxy Einstellungen bei uns Arbeit immer eine "veraltete" Version ziehe - werde zu Hause mal die EXE downloaden und die dann probieren.
@Blinky, wenn niemand anderes dieses Problemchen hat, hat sichs eigentlich erledigt, ich kann mit der Meldung leben, sonst läuft es ja prima...
Schau mal in den Ordner, wo die Daten abgelegt werden. Dort findest Du die Datei Version. Diese dient zum abgleichen. Die müßte bei Dir 0.0.0.44 anzeigen.
Aktive Benutzer in diesem Thema: 8 (Registrierte Benutzer: 0, Gäste: 8)
