Ergebnis 1 bis 8 von 8
Thema: monitord mit aktuellem Kernel komplilieren
    die Pakete für LUA haben vorher auf jeden Fall gefehlt...
    Code:
    sudo apt-get install autoconf libtool libasound2-dev medit
    sudo apt-get install lua5.2 liblua5.2-dev
    sudo autoreconf -fi   # => schlägt fehl
    # Makefile.a:2  ":" entfernt
    echo "m4_ifdef([AM_PROG_AR], [AM_PROG_AR])" >> configure.ac
    echo LT_INIT >> configure.ac
    sudo autoreconf -fi   # => läuft durch
    ./configure --with-alsa --with-lua-includes=/usr/include/lua5.2 --with-lua-suffix=5.2
    ein folgendes make endet auch wieder mit Fehler...
    Code:
    make  all-am
    make[1]: Entering directory '/home/srv/monitord-bin+src'
    g++ -DHAVE_CONFIG_H -I.  -Ijthread-1.2.1/src -D_DEBUG -Wall -I/usr/include/lua5.2       -g -O2 -MT monitord/monitord_monitord-MonitorConfiguration.o -MD -MP -MF monitord/.deps/monitord_monitord-MonitorConfiguration.Tpo -c -o monitord/monitord_monitord-MonitorConfiguration.o `test -f 'monitord/MonitorConfiguration.cpp' || echo './'`monitord/MonitorConfiguration.cpp
    Makefile:1165: recipe for target 'monitord/monitord_monitord-MonitorConfiguration.o' failed
    make[1]: Leaving directory '/home/srv/monitord-bin+src'
    Makefile:644: recipe for target 'all' failed
    make  all-am
    In file included from monitord/MonitorConfiguration.cpp:16:0:
    ./simpleopt/SimpleGlob.h: In instantiation of ‘int CSimpleGlobTempl::Add(const SOCHAR*) [with SOCHAR = char]’:
    ./simpleopt/SimpleGlob.h:687:41:   required from ‘int CSimpleGlobTempl::Add(int, const SOCHAR* const*) [with SOCHAR = char]’
    monitord/MonitorConfiguration.cpp:334:62:   required from here
    ./simpleopt/SimpleGlob.h:623:55: error: ‘GetFileTypeS’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
             SG_FileType nType = GetFileTypeS(a_pszFileSpec);
    ./simpleopt/SimpleGlob.h:623:55: note: declarations in dependent base ‘SimpleGlobBase’ are not found by unqualified lookup
    ./simpleopt/SimpleGlob.h:623:55: note: use ‘this->GetFileTypeS’ instead
    ./simpleopt/SimpleGlob.h:644:53: error: ‘FindFirstFileS’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
         int rc = FindFirstFileS(a_pszFileSpec, m_uiFlags);
    ./simpleopt/SimpleGlob.h:644:53: note: declarations in dependent base ‘SimpleGlobBase’ are not found by unqualified lookup
    ./simpleopt/SimpleGlob.h:644:53: note: use ‘this->FindFirstFileS’ instead
    ./simpleopt/SimpleGlob.h:657:51: error: ‘GetFileNameS’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
             nError = AppendName(GetFileNameS((SOCHAR)0), IsDirS((SOCHAR)0));
    ./simpleopt/SimpleGlob.h:657:51: note: declarations in dependent base ‘SimpleGlobBase’ are not found by unqualified lookup
    ./simpleopt/SimpleGlob.h:657:51: note: use ‘this->GetFileNameS’ instead
    ./simpleopt/SimpleGlob.h:657:70: error: ‘IsDirS’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
    ./simpleopt/SimpleGlob.h:657:70: note: declarations in dependent base ‘SimpleGlobBase’ are not found by unqualified lookup
    ./simpleopt/SimpleGlob.h:657:70: note: use ‘this->IsDirS’ instead
    ./simpleopt/SimpleGlob.h:658:43: error: ‘FindNextFileS’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
             bSuccess = FindNextFileS((SOCHAR)0);
    ./simpleopt/SimpleGlob.h:658:43: note: declarations in dependent base ‘SimpleGlobBase’ are not found by unqualified lookup
    ./simpleopt/SimpleGlob.h:658:43: note: use ‘this->FindNextFileS’ instead
    make[1]: *** [monitord/monitord_monitord-MonitorConfiguration.o] Error 1
    make: *** [all] Error 2
    Weiß jemand weiter?
    Geändert von felix000 (27.08.2016 um 16:54 Uhr)
    Felix
    Habe leider das gleiche Problem. Habe bisher keine Lösung gefunden. Hat es mittlerweile wieder jemand ans Laufen gekriegt?
    Versuch mal den gcc mit der Version 4.6.*
    in einer mingw/msys Umgebung geht make nur mit einer gcc und c++ Version 4.6.* ab Version 4.7.* und neuer kommt der selbe Fehler.
    Hatte das selbe Problem habs mit der gcc version 4.6 erforlgeich probiert:
    Code:
    sudo apt-get remove gcc
    sudo apt-get install gcc-4.6 g++-4.6
    sudo ln -s /usr/bin/gcc-4.6 /usr/bin/gcc
    sudo ln -s /usr/bin/g++-4.6 /usr/bin/g++
    Danach noch:
    Code:
    sudo make install
    Jetzt kämpfe ich da:
    Code:
    monitord
     15:20:19.910 INFO: monitord/Monitor.cpp(70) Logging with loglevel DEBUG
     15:20:19.911 DEBUG: monitord/MonitorModulesResults.cpp(51) Dispatcher startet
     15:20:19.913 INFO: monitord/Monitor.cpp(113) monitord 2.0svn READY
    monitord 2.0svn running...
     15:20:19.924 INFO: monitord/Monitor.cpp(217) starting soundcard #0
     15:20:19.924 INFO: monitord/SndPipe.cpp(152) creating decoders for soundcard #0
     15:20:19.924 INFO: monitord/SndPipe.cpp(156) creating decoder for soundcard #0L:FMS
     15:20:19.925 DEBUG: monitord/MonitorModuleFMS.cpp(100) FMS Parameter
     15:20:19.925 DEBUG: monitord/MonitorModuleFMS.cpp(101) sample : 22050
     15:20:19.926 DEBUG: monitord/MonitorModuleFMS.cpp(102) syncbits: 12
     15:20:19.926 DEBUG: monitord/MonitorModuleFMS.cpp(103) crc    : 1
     15:20:19.926 DEBUG: monitord/MonitorModuleFMS.cpp(104) level  : 0.15259
     15:20:19.927 DEBUG: monitord/MonitorModuleFMS.cpp(105) Algo   : 0
     15:20:19.927 DEBUG: monitord/MonitorModuleFMS.cpp(106) ignW   : 0
     15:20:19.928 DEBUG: monitord/MonitorModuleFMS.cpp(107) ignQ   : 0
     15:20:19.928 DEBUG: monitord/MonitorModuleFMS.cpp(108) ErrC   : 0
     15:20:19.928 DEBUG: monitord/MonitorModuleFMS.cpp(109) force   : 0
     15:20:19.929 INFO: monitord/SndPipe.cpp(178) creating decoder for soundcard #0L:ZVEI
     15:20:19.930 INFO: monitord/SndPipe.cpp(189) creating decoder for soundcard #0R:ZVEI
    ALSA lib pcm_hw.c:1667:(_snd_pcm_hw_open) Invalid value for card
     15:20:19.940 ERROR: monitord/posix/MonitorAudioALSA.cpp(56) [ALSA] Error opening PCM device plughw:1,0 ret:-2No such file or directory
     15:20:19.941 ERROR: monitord/posix/MonitorAudioALSA.cpp(16) [ALSA] Error initializing PCM device plughw:1,0
    Bei mir läufts nun auf dem aktuellen RASPBIAN (2017-11-29).
    Einziges Problem wenn ich's über crontabs starten bzw. überwachen will.
    /etc/init.d/funk
    (chmod 755)
    Code:
    case "$1" in
        start)
    		/home/pi/Documents/monitord/monitord -c /home/pi/Documents/monitord/monitord.xml >> /dev/null &
    		echo "Monitord wurde gestartet"
        stop)
    		pid=$(pidof monitord)
    		kill $pid
    		echo "Monitord wurde beendet"
    	restart)
    		kill $pid
    		echo "usage $0 start|stop|restart" ;;
    esac
    exit 0
    als user pi via ssh Aufruf funktioniert es:
    /etc/init.d/funk start
    allerdings via crontab:
    * * * * * /etc/init.d/funk start >> /tmp/crontab.log
    gibt es zwar einen Eintrag in der Logdatei, aber monitord wurde nicht gestartet.
    Leider ist mit Linux Knowhow leider nicht ausreichend, dass ich eine Idee hab ob's an Berechtigungen, etc. etc. liegt?
    Jemand ne Idee / Tipp?
    könnte am User liegen...entweder in der crontab den User mit angeben oder mal das Script in einer Root-Shell (sudo -i) versuchen zu starten...
    Felix
    Ich hab's mit dem alten gcc auch kompilieren können und es läuft jetzt als systemd-Dienst stabil...
    LUA hab ich jetzt weggelassen, gab nen Fehler beim configure-Befehl, den ich nicht länger untersucht hab.
    Meine Vorgehensweise:
    Code:
    tar xfvj monitor-trunk.tar.bz
    cd trunk/
    sudo autoreconf -fi
    sudo make install
    Jetzt fehlt mir eigentlich nur noch snd-aloop... Falls mir hier jemand helfen kann, bitte in diesem Thread: https://www.funkmeldesystem.de/threa...m-Raspberry-Pi
    Felix
