Install XPe tools and imager on DOK
Once you have completed the creation of the bootable USB drive, you will need to install the XPe SP2 tools and imager on the DOK. Double click on the Icon for the SP29705.exe file you saved in the earlier step. Follow the instruction on the installation. Once installed, a window will open asking you what kind of ISO image you want to create. Select USB Format. You will be asked to select the drive of the USB DOK. Please make sure you select the drive letter where you have the DOK placed, then click format. Once completed the utility will tell you format is complete. The format takes about 3-4 minutes for a 1Gb thumb drive. Click the OK button and close the window. Remove the USB DOK from your PC.
Bei diesem Schritt komme ich nicht weiter. was muss ich nun mit den Tool machen?
