Ergebnis 1 bis 15 von 69
Thema: Email Überwachung Fehler
    Zitat Zitat von C-A-F-S Beitrag anzeigen
    Weiterhin keine Verbindung zum Postfach bei mir:
    19.04.2013 - 21:13:44.885 ERROR MailInput - Software caused connection abort: recv failed
    javax.mail.MessagingException: Software caused connection abort: recv failed at com.sun.mail.imap.IMAPStore.protocolConnect(IMAPSt ore.java:665) ~[firEmergency.jar:na]
    at javax.mail.Service.connect(Service.java:317) ~[firEmergency.jar:na]
    at javax.mail.Service.connect(Service.java:176) ~[firEmergency.jar:na]
    at javax.mail.Service.connect(Service.java:125) ~[firEmergency.jar:na]
    at mailInput.MailInput.connectToStore(MailInput.java: 156) ~[MailInput.jar:na]
    at mailInput.MailInput.run(MailInput.java:113) ~[MailInput.jar:na]
    Caused by: java.net.SocketException: Software caused connection abort: recv failed
    at java.net.SocketInputStream.socketRead0(Native Method) ~[na:1.7.0_17]
    at java.net.SocketInputStream.read(Unknown Source) ~[na:1.7.0_17]
    at sun.security.ssl.InputRecord.readFully(Unknown Source) ~[na:1.7.0_17]
    at sun.security.ssl.InputRecord.read(Unknown Source) ~[na:1.7.0_17]
    at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source) ~[na:1.7.0_17]
    at sun.security.ssl.SSLSocketImpl.performInitialHands hake(Unknown Source) ~[na:1.7.0_17]
    at sun.security.ssl.SSLSocketImpl.startHandshake(Unkn own Source) ~[na:1.7.0_17]
    at com.sun.mail.util.SocketFetcher.configureSSLSocket (SocketFetcher.java
    :507) ~[firEmergency.jar:na]
    at com.sun.mail.util.SocketFetcher.getSocket(SocketFe tcher.java:238) ~[firEmergency.jar:na]
    at com.sun.mail.iap.Protocol.<init>(Protocol.java:113 ) ~[firEmergency.jar:na]
    at com.sun.mail.imap.protocol.IMAPProtocol.<init>(IMA PProtocol.java:110)
    at com.sun.mail.imap.IMAPStore.protocolConnect(IMAPSt ore.java:632) ~[firEmergency.jar:na]
    ... 5 common frames omitted
    Dieser Fehler hat nichts mit der eigentlichen Problematik zu tun. Hier scheint ein Virenscanner oder Firewall die Verbindung zum Server zu blockieren.
    habe beides mal deaktiviert, die gleiche Fehlermeldung kommt weiterhin.
    Habe die neue Version nu mal in ner VM getestet, läuft seit über 6 Stunden stabil. Werde es nun im Realem Einsatz testen.
    Welchen E-Mailprovider / IMAP-Server verwendest du?
