ich bekomme das Tool einfach nicht mit mySQL Support unter Ubuntu zum Laufen. Egal welche Pakete ich noch auf das System bringe, aber ich erhalte niemals eine dll-Datei im Pluginverzeichnis, daher auch die Meldung:
Ich kompiliere so:Code:22:16:53.417 INFO: monitord/Monitor.cpp(68) monitord restarted - logging with loglevel INFO 22:16:53.418 INFO: monitord/Monitor.cpp(113) monitord 2.0svn READY 22:16:53.422 INFO: monitord/Monitor.cpp(217) starting soundcard #0 22:16:53.422 INFO: monitord/SndPipe.cpp(152) creating decoders for soundcard #0 22:16:53.422 INFO: monitord/SndPipe.cpp(178) creating decoder for soundcard #0L:ZVEI 22:16:53.423 INFO: monitord/SndPipe.cpp(201) creating decoder for soundcard #0L:POC512 22:16:53.423 INFO: monitord/MonitorModulePocsag512.cpp(66) (2) sample - crc - ecc - minpreambel - maxerrors - algo:22050 - 1 - 0 - 300 - 10 - 1 22:16:53.423 INFO: monitord/MonitorModulePocsag512.cpp(79) Algorithmus:1 22:16:53.423 INFO: monitord/MonitorModulePocsag512.cpp(86) SPHASE_INC is:1521 22:16:53.423 INFO: monitord/SndPipe.cpp(228) creating decoder for soundcard #0L:POC1200 22:16:53.423 INFO: monitord/SndPipe.cpp(263) loading audioplugins for left channel 22:16:53.423 INFO: monitord/SndPipe.cpp(283) plugin file:0=monitord/plugins/.libs/libmplugin_audiorecorder.so.0.0.0 22:16:53.423 INFO: monitord/SndPipe.cpp(304) Plugin# 0: loading audio plugin using: monitord/plugins/.libs/libmplugin_audiorecorder.so.0.0.0 22:16:53.423 ERROR: monitord/plugins/dll-elf.cpp(15) error loading library file "monitord/plugins/.libs/libmplugin_audiorecorder.so.0.0.0" 22:16:53.423 ERROR: monitord/SndPipe.cpp(325) Error plugin Factory from file monitord/plugins/.libs/libmplugin_audiorecorder.so.0.0.0 22:16:53.423 INFO: monitord/SndPipe.cpp(265) loading audioplugins for right channel 22:16:53.459 INFO: monitord/posix/MonitorAudioALSA.cpp(107) [ALSA] Using pcm_buffer_size=16384 periods=2 22:16:53.462 INFO: monitord/Monitor.cpp(225) Soundcard #0 started - complete 22:16:53.463 INFO: monitord/Monitor.cpp(147) monitord socketserver started 22:16:53.465 INFO: monitord/Monitor.cpp(153) fms32pro socketserver started 22:16:53.466 INFO: monitord/Monitor.cpp(158) crusader socketserver started 22:16:53.466 INFO: monitord/PluginThread.cpp(326) reading plugin configuration 22:16:53.466 INFO: monitord/PluginThread.cpp(337) Plugin found: mysql 22:16:53.466 ERROR: monitord/plugins/dll-elf.cpp(15) error loading library file "plugins/libmplugin_mysql-0.dll" 22:16:53.466 ERROR: monitord/Monitor.cpp(132) monitord/PluginThread.cpp Line 53: Error accessing factory from plugins/libmplugin_mysql-0.dll
./configure --enable-plugins --with-mysql --with-alsa
make
Was mache ich falsch?
