Thema: SGA Pro + DE925 serial output problem
    the "@p" command is to read out the Messages of the DE925-Memory.
    We have learnd that you need to send the command 2 times behind each other.
    SY Fabsi
    Thank you for your reply which helped me. I solved the problem now. Had to wait also from 150ms - 500ms difference between sending commands together.
    Is there any other command to send over serial port for example to delete all messages or just 1 message?
