Ergebnis 1 bis 15 von 310
Thema: Tutorial e-Mail und SMS Alarm
    das ganze geht auch ohne blat usw.
    ---------------------*.vbs datei----------------------
    Set ws = CreateObject("WScript.Shell")
    Dim FS, DS, File, Pfad, Anhang, ENachricht, NachRicht
    Const cdoSendUsingPickup = 1
    Const cdoSendUsingPort = 2
    Const cdoAnonymous = 0
    Const cdoBasic = 1
    Const cdoNTLM = 2
    ' SEND MAIL
    Pfad = "D:\emailalarm\test\"
    if Pfad = "" then
    AuS
    else
    'nix
    end if
    Set objMessage = CreateObject("CDO.Message")
    objMessage.Subject = "AlarmFax - Am " & date & " um " & time
    objMessage.From = """AlarmFax"" "
    objMessage.To = " objMessage.TextBody = "AlarmFax - Am " & date & " um " & time & " Uhr"
    'Dateien
    Set FS = CreateObject("Scripting.FileSystemObject")
    If FS.FolderExists (Pfad)=True Then
    'msgbox "Ordner ist da!",vbinformation,"Ordner da!"
    Set DS = FS.GetFolder(Pfad)
    for Each File in DS.Files
    Anhang = File.Name
    objMessage.AddAttachment Pfad & Anhang
    next
    Set DS = Nothing
    Set FS = Nothing
    else
    msgbox "Ordner ist nicht da!",vbinformation,"Ordner nicht da!"
    set FS = nothing
    end if
    'Konfiguration SMTP Server
    objMessage.Configuration.Fields.Item _
    ("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
    ("http://schemas.microsoft.com/cdo/configuration/smtpserver") = "mail.gmx.de"
    'Type of authentication, NONE, Basic (Base64 encoded), NTLM
    ("http://schemas.microsoft.com/cdo/configuration/smtpauthenticate") = cdoBasic
    'Your UserID on the SMTP server
    ("http://schemas.microsoft.com/cdo/configuration/sendusername") = "BENUTZERNAME"
    'Your password on the SMTP server
    ("http://schemas.microsoft.com/cdo/configuration/sendpassword") = "PASSWORT"
    'Server port (typically 25)
    ("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = 25
    'Use SSL for the connection (False or True)
    ("http://schemas.microsoft.com/cdo/configuration/smtpusessl") = False
    'Connection Timeout in seconds (the maximum time CDO will try to establish a connection to the SMTP server)
    ("http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout") = 60
    objMessage.Configuration.Fields.Update
    objMessage.Send
    Set objMessage = Nothing
    AuS
    Private Sub AuS
    WScript.Quit
    End Sub
    ich hätte nochmals eine Frage. Ich benutze für den Versand von den Emails als Provider meine "Vodafone MobileMail" Adresse.
    Was habt ihr für eine Erfahrung mit euerem Provider und wie ist es mit der Zeitverzögerung der Mail's? Bei "web.de" ist es oft so, das diese erst etliche Minuten später gesendet werden?
    Danke schon mal für die Antworten.
    nore112
    Hey,
    ich habe mir zuzätzlich zu meiner Haupt GMX Adresse eine weitere E-Mail Adresse für den Alarm Versand eingerichtet. ( Kannst pro Acc. mehrere Adressen einrichten glaube 3 oder 5 oder so ... alles kostenlos ! ) Kannst dir dann sogar ne schöne Adresse ausdenken und benutzen !
    Bin sehr zufrieden mit GMX, lief bisher immer Top !
    MFG Beatzler
    Musste damals auch feststellen dass die Mails bei Web.de teilweise 5 minuten dauern bis sie übermittelt werden.
    Bin wieder zurück zu gmx gewechselt dort sind die Mails innerhalb von 10-15 sek da.
    Habe auch jetzt das Problem, dass das blat-Programm einwandfrei funktioniert, wenn ich die Datei "alarm" manuell starte (per Doppelklick). Die Mail wird dann einwandfrei verschickt.
    Wenn ich jedoch die Datei im das Aktionsfeld starte, dann flackert kurz das schwarze Fenster auf (also Datei wird auch gestartet), aber es verschwindet sofort wieder und es findet auch kein Mailversand statt. Es wird auch kein log-file im Ordner erstellt. Irgendwas funktioniert nicht.
    Der Eintrag im Aktionsfeld es Empfängers sieht so aus:
    c:\emailalarm\alarm.bat "%1" "%2" "%3" "%4"
    Welche Funktion haben eigentlich die Angaben "%1" bis "%4"...? Brauch ich die alle?
    Hier mal meine Datei:
    echo Am %date% um %time:~0,8% Melderausloesung Schleife %* > c:\emailalarm\mailinhalt.txt
    c:\emailalarm\blat.exe "c:\emailalarm\mailinhalt.txt" -to MAILADRESSE -server mail.web.de -u USER -pw PASSWORT -timestamp -log versandlog.txt -subject "%date% um %time:~0,8% Melderausloesung Schleife %*"
    del c:\emailalarm\mailinhalt.txt
    del c:\emailalarm\subject.txt
    end
    Das Versandlog sieht dann so aus. Dies funktioniert aber NUR, wenn ich die alarm.bat manuell per Doppelklick starte. Über FMS32 wird kein Log erstellt.
    2009.12.26 16:44:33 (Sat)------------Start of Session-----------------
    Blat v2.6.2 w/GSS encryption (build : Feb 25 2007 12:06:19)
    2009.12.26 16:44:36 (Sat): Sending c:\emailalarm\mailinhalt.txt to MEINE MAILADRESSE
    2009.12.26 16:44:36 (Sat): Subject: 26.12.2009 um 16:44:33 Alarm auf die Schleife
    2009.12.26 16:44:36 (Sat): Login name is MEINE MAILADRESSE
    2009.12.26 16:44:36 (Sat)-------------End of Session------------------
    Danke und Gruß,
    Thorsten
    Geändert von Thors1204 (26.12.2009 um 21:06 Uhr)
