Ergebnis 1 bis 15 von 16
Thema: Motorola GP300 Select 5
    Hoppla, jetzt lese ich gerade Hardwarefehler2.
    Was für einen Schnittstellenkonverter hast Du denn angeschlossen?
    Original-RIB, Nachbau-RIB, oder RIB-less mit dem MAX232?
    Wenn letzteres, dann die Schaltung mit oder ohne 7407?
    Bei einigen Geräten gibt es da Probleme mit den Vorwiderständen der LED
    Notes:
    If you have problems getting this interface to work on your GP300, then try replacing the two 680 ohm resistors that feed the LED's. If you use 4.7k ohm it should work OK. I found that when using version R01.00.00 software I have no problems with the 680 ohm resistors, but for some reason when I ran the newer software (R08.02.00) I had problems reading the codeplug etc. All I have done is replaced the 680 ohm with 4.7k ohm and it works fine now with both versions of software. You will have to experiment a little and let me know what resistors work for you.
    Simon VK4TSC encountered a problem where the GP300 being programmed/read will fail to pass data to/from the computer with an Error #2 (Serial Bus Error). After checking the BUS+ line with a CRO it was found that the GP300 could not properly switch the data bus, this being caused by the led/resistor combination on the data bus drawing a little more current than the radio could supply. By changing the series resistor to 1K ohm instead of 680 ohm the problem was overcome
    The better solution maybe to use a spare gate from the 7407 to drive the led separately. Disconnect led cathode and link it to pin 4 of 7407, isolate pin 3 of 7407 from 5V and link it to pin 2 of same chip. The original 680 ohm series resistor can be left as is. BUS+ is now isolated from the data led.
    Quelle: http://www.g1ivg.com/motgp300.htm
    Gruß - Karlson
    Meine Rechtschreibfehler gehören mir
    Benutze zzt die GP 300 Schaltung von Flasche
    http://www.ginko.de/user/flasche/familie/prg300gr.jpg
    wie gesagt, bislang keine GP300 Probleme gehabt.
    Das Sel 5 Gerät das ich zu programmieren versuche ist ein Gerät, welches bislang nur vom Händler programmiert wurde.
    Also ist die Wahrscheinlichkeit einer vorangegangenen SW Modifikation doch sehr gering.
    Ich werd' mich noch mal um eine etwas andere Hardware kümmern...
    hätt' ich doch nur noch ein paar von diesen SUB D's herumliegen *g*, aber irgendwas ist ja immer
    Danke dir erstmal für die Tipps und Denkansätze.
    Melde mich wenn ich neue Erkenntnisse habe.
    Manchmal kommt man einfach nicht zur Ruhe...
    Habe gesucht bis ich endlich die benötigten Kleinteile hatte.
    Mit der RIB von Servicetools.org exakt das gleiche Ergebniss :-(
    Das 'kleine' GP 300 lässt sich lesen und schreiben,
    das Select 5 wehrt sich noch immer mit Hardwarefehler 2
    *RatlosNebenDemFugSitz*
    Den Fehler kann ich hier nur nachvollziehen, wenn die "RIB" am Rechner angeschlossen ist, aber die Busleitung nicht am Funkgerät.
    Die "Flascheschaltung" ist in Ordnung, aber der obere Teil mit der Spannungsversorgung ist ein wenig irritierend. Nach dieser Schaltung würde das Funkgerät ja nur 5V erhalten, was aber garantiert nicht funktioniert.
    Das Gerät bekommt 7,5V Spannug, die Software läuft im reinen DOS-Modus (über DOS Startdiskette)?
    Karlson
    Hmm,
    also Flasche Schaltung:
    Da habe ich nur den BUSteil übernommen.
    eine andere externe Spannungsversorgung zugeführt.
    beim lesen für ca. 2 sek. Daten LED
    dann laaaaaange garnichts
    Fehlermeldung : Hardwarefehler beim Datentransfer:2
    RIB:
    Auch den BUS der RIB
    keine LED daher nichts angezeigt
    laaange nichts
    dann Fehlermeldung : Hardw....:2
    Kontaktiervorrichtung ist in beiden Fällen die von Servicetools.org
    und die ist wirklich gut !
    das "kleine" lässt sich ja mit selber Hardware problemlos bearbeiten.
    Jetzt mal ein zweites GP300 Sel5 Gerät zum testen bekommen (gleiche Firma woher das 'erste' stammt.)
    Auch absolut keine Chance zu programmieren.
    Werde die nächsten Tage mal einen anderen Rechner zum testen zusammenstricken...kann ja eigentlich nur noch an der Seriellen Schnittstelle liegen (relativ schneller PC, 350 Mhz) *anStrohalmKlammer*
    (bzw... mir Dussel fällt gerade auf das auf dem Rechner kein MS-DOS sondern DR-DOS installiert ist...
    Werde den beiden Ideen noch mal auf den Grund gehen!
    in beiden Fällen würde es mich jedoch wundern warum das 'kleine' so problemlos zu bearbeiten ist.
    Danke erstmal !
    Na, dann will ich Dir den Strohhalm mal entreißen ;-)
    Ich programmiere meine Geräte mit einem 400er PC und einem 800er Laptop...
    Es kann nur am FuG liegen, wenn dann auch noch von der selben Firma - vielleicht doch gelockt?
    *soauchlangsamratloswerd* - Karlson
    also das das Gerät auf die "unübliche" Weise "verriegelt" ist, ist ja durchaus möglich. Aber irgendwie auch nicht sehr wahrscheinlich...
    Kannst du in der "Ursprungsfirma" nicht mal nachfragen?
    Ansonsten:
    Es ist ja durchaus auch nicht unmöglich, das dass Gerät (die Geräte) im Bereich der Schnittstelle defekt sind! Ich habe einige MT2100 gehabt, die sich auch nicht proggen ließen, da war einmal die "Flex-Folie" oder auch wirklich die Schnittstelle defekt.
    Auch eine defekte RIB-Box kann die Ursache sein...
    Mich selbst hat das schon ein GP360 gekostet ;-(
    Naja, Shit Happens!
    BTW:
    Hat jemand die Belegung des GP300 Programmierkabels für die RIB-BOX, also nicht die des bekannten einfachen RIBLESS Kabels.
