Noch mal ein Feedback an dieser Stelle:
Das mit dem neu runterladen etc. hat nichts gebracht.
Der AM3 hängt sich nach wie vor auf. Aufgrund der Fehlermeldungen tippe ich auf ein Problem mit Google Maps.
Code:!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2015-04-16 21:39:31.423 !MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt". !STACK 0 org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:62) at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:888) at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:869) at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:390) at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:143) at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:76) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:107) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:70) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:175) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.clearContext(PartRenderingEngine.java:974) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:954) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$3(PartRenderingEngine.java:862) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$8.run(PartRenderingEngine.java:857) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.removeGui(PartRenderingEngine.java:841) at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.disposeWidget(ElementReferenceRenderer.java:118) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:933) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$3(PartRenderingEngine.java:862) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$8.run(PartRenderingEngine.java:857) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.removeGui(PartRenderingEngine.java:841) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:894) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$3(PartRenderingEngine.java:862) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$8.run(PartRenderingEngine.java:857) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) ............. !ENTRY org.eclipse.e4.ui.workbench 4 0 2015-04-16 21:39:31.428 !MESSAGE Exception occurred while unrendering: org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl@16688fe (elementId: de.alamos.monitor.view.googlemaps.view, tags: [View, categoryTag:Karte], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (contributionURI: bundleclass://org.eclipse.ui.workbench/org.eclipse.ui.internal.e4.compatibility.CompatibilityView, object: null, context: null, variables: [], label: Google Maps, iconURI: platform:/plugin/de.alamos.monitor.view.googlemaps/icons/maps.png, tooltip: null, dirty: false, closeable: true, description: null) !STACK 0 org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:62) at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:888) at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:869) at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:390) at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:143) at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:76) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:107) at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:70) at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:175) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.clearContext(PartRenderingEngine.java:974) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:954) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$3(PartRenderingEngine.java:862) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$8.run(PartRenderingEngine.java:857) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.removeGui(PartRenderingEngine.java:841) at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.disposeWidget(ElementReferenceRenderer.java:118) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:933) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$3(PartRenderingEngine.java:862) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$8.run(PartRenderingEngine.java:857) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
Heute hat es sich wie folgt verhalten:
- Der Bildschirmschoner hat sich nicht beendet (was er normalerweise tut)
- Während des Alarms gab es im Log keine Auffälligkeiten
- Als ich anschließend noch einmal per VNC auf den AM3 PC geschaut habe, ist der AM wieder eingefroren.
Ok, dann müssen wir das mit deinem Workspace nachstellen.
Bitte ein Ticket öffnen mit Verweis auf diesen Thread und deinen AM3-Workspace anhängen.
Eventuell kurze Anleitung wie wir den Fehler genau reproduzieren können.
