Da kann ich helfen.
Im Anhang ein Auszug aus meinem Icast2 Meata-Update:
GrußCode:# Icecast Meta-Update import urllib2 icecastrun = process_num("icecast2") ezstreamrun = process_num("ezstream") if int(icecastrun) > 0 and int(ezstreamrun) > 0: print "Icecast und ezstream laufen" metadata = str(datum) + " " + str(zeit) + " [" + str(schleife) + "] " + str(org) + " " + str(ort) + " " + str(bez) metadata = metadata.replace(" ","+") #add "+" instead of " " for icecast2 url = "http://" + str(icecast_server) + ":" + str(icecast_port) + "/admin/metadata?mount=/" + str(icecast_mountpoint) + "&mode=updinfo&charset=UTF-8&song=" + str(metadata) # simple wrapper function to encode the username & pass def encodeUserData(user, password): return "Basic " + (user + ":" + password).encode("base64").rstrip() # create the request object and set some headers req = urllib2.Request(url) req.add_header('Accept', 'application/json') req.add_header("Content-type", "application/x-www-form-urlencoded") req.add_header('Authorization', encodeUserData(icecast_user, icecast_password)) # make the request and print the results res = urllib2.urlopen(req) print res.read() else: print "Icecast oder/und ezstream laufen nicht"
Marcel
