Hallo Daniel,
das Problem war (nicht zum erstenmal) die erste Zeile mit dem Status ("100;...") - die ;-Abrennung eines menschenlesbaren Kommentars war noch nicht sinnvoll drin. Außerdem hatte ich keine zeilenweise Behandlung der Socket-Rückgaben eingebaut.
Ist jetzt drin, Tests und Ergebnisse gerne gesehen, müsste mit Deiner Klasse tun nun :).
Viele Grüße
Martin
Code der Klasse:
	Code:
	<?php
* @brief minimalistic monitord PHP client - connects via socket and can react on ZVEI, FMS, POCSAG telegrams
* @author mdiedrich/Martin Diedrich 08/2013
class monitord_php_client {
	* @brief constructor including main() loop
	function monitord_php_client($host='localhost', $port='9333') {
		$this->host = $host;
		$this->port = $port;
		$this->socket = null;
		$this->sock_retrycount = 0;
		$this->sock_errcount = 0;
		$this->errorcode = 0;
		$this->sleeptime = 10;
		while($this->monitord_socket_error_handler() === true) {
	* @brief split and work through single lines if socket_read contained more then one line
	* @param $in data read from socket
	function monitord_socket_parse($in) {
		$monitord_lines_array = explode(PHP_EOL, $in);
		foreach($monitord_lines_array as $out) {
			$this->monitord_socket_parse_line($out);
	* @brief parses input data from socket, mainly calling function depending on type
	* @param $in single line to be handled
	function monitord_socket_parse_line($in) {
		if($in != "") {
			// cut off human readable information (delimited by ';') first
			// make it usable in array field named 'human_readable' later
			$position = strpos($in, ';');
			$human_readable = '';
			if($position !== false) {
				$human_readable = substr($in, $position+1);
				$in = substr($in, 0, $position);
			// NEXT LINE FOR DEBUGGING ONLY
			// echo "\nIN AND HR: " . $in . ' - ' . $human_readable . "\n\n";
			// explode machine readable data on ':' and add human readable
			$monitord_line = explode(':', $in);
			$monitord_line['human_readable'] = $human_readable;
			// switch by monitord protocol code
			switch($monitord_line['0']) {
				case '300' : $this->monitord_work_zvei($monitord_line);break;
				case '310' : $this->monitord_work_fms($monitord_line);break;
				case '320' : $this->monitord_work_pocsag($monitord_line);break;
				default : $this->monitord_work_unknown($monitord_line);
			return true;
		} else {
			return false;
	* @brief main part, connecting and reading from socket calling parser method
	* @return bool true normally, false on critical failure
	function monitord_socket_error_handler() {
		if($this->socket === null) {
			$socket = @socket_create(AF_INET, SOCK_STREAM, SOL_TCP);
			if ($socket === false) {
				$this->errorcode = socket_last_error($socket);
				echo 'ERR_ABORT: ' . $this->errorcode;
				return false;
			} else {
				echo "INFO: Socket created.\n";
				$this->socket = $socket;
		$out = @socket_read($this->socket, 1024, PHP_BINARY_READ);
		$this->errorcode = socket_last_error($this->socket);
		// echo "DEBUG: errorcode was $this->errorcode -- out was ";
		// var_dump($out);
		if( ($this->sock_retrycount < 10) && ($this->errorcode == 10054 || $this->errorcode == 10057) ) {
			if($this->errorcode == 10054) {
				socket_shutdown($this->socket);
				socket_close($this->socket);
				return true;
			socket_clear_error($this->socket);
			$address = gethostbyname($this->host);
			echo "INFO: Trying to connect $address ...\n";
			$result = @socket_connect($this->socket, $address, $this->port);
			if ($result == false) {
				echo 'WARN: Socket could not be connected. Retrying in ' . ($this->sleeptime * ($this->sock_retrycount+1)) . 's (';
				echo $this->sock_retrycount+1 . "/10).\n";
				$this->sock_retrycount++;
				sleep($this->sleeptime * ($this->sock_retrycount+1));
				return true;
			} else {
				echo "INFO: Socket connected.\n";
				return true;
		if($this->sock_retrycount == 30) {
			echo "ERR_ABORT: Socket retrycount (30) exceeded, exiting.";
			return false;
		$this->monitord_socket_parse($out);
		return true;
	* @brief handling FMS data
	* @param $monitord_line (310:{Zeit}:Kanalnummer:FMSKennung:Status:Baustufe:Richtung:TKI:FMSText)
	function monitord_work_fms($monitord_line) {
		echo "INFO: FMS received [".$monitord_line["2"].":".$monitord_line["3"].":".$monitord_line["6"].":".$monitord_line["4"]."]\n";
	* @brief handling ZVEI data
	* @param $monitord_line (300:Zeit:Kanalnummer(char):Schleife(text5):Sirenenalarmierung(char):Text)
	function monitord_work_zvei($monitord_line) {
		echo "INFO: ZVEI received [".$monitord_line["2"].":".$monitord_line["3"]."]\n";
	* @brief handling POCSAG data
	function monitord_work_pocsag($monitord_line) {
		echo "INFO: POCSAG received\n";
	* @brief handling data of unknown type
	function monitord_work_unknown($monitord_line) {
		echo "INFO: UNKNOWN received, dumping:\n";
		var_dump($monitord_line);
		echo "\n";
 Instanziierung:
	Code:
	<?php
	require_once('./monitord_php_client.class.php');
	echo "\nmonitord PHP Client v0.2 started\n\n";
	$mpc = new monitord_php_client();
 Angepasster Code (abgeleitete Klasse von Daniel):
	Code:
	class test_monitord_php_client extends monitord_php_client{
	function __construct($host='localhost', $port='9333') {
		$this->debug = true;
		parent::__construct($host, $port);
		* dump all content for debugging process
		echo "\n";
 		 *  Prüfung ob OK empfangen wurde
		if($monitord_line['0'] == '100') {
			sleep(2);
			$cmd = "210\r\n";
			$write = socket_write($this->socket, $cmd, strlen($cmd));
			echo "Es wurden " . $write . " Bytes geschrieben";
			echo "\n";
			$errorcode = socket_last_error($this->socket);
			if($errorcode != 0 && $this->debug){
				echo "DEBUG: errorcode was $this->errorcode ( " . socket_strerror($errorcode) . " )-- out was ";
				var_dump($out);
