Hallo, ich bekomme aPager für iOS nicht zum laufen.
SendMessageApagerIOS - Fehler beim Push-Versand: Communication exception: java.net.ConnectException: Connection refused: connect
aktuelle Version FE
Java 6
Win XP
Auszug Log:
02.05.2013 - 09:13:22.002 ERROR SendMessageApagerIOS - Fehler beim Push-Versand: Communication exception: java.net.ConnectException: Connection refused: connect
javapns.communication.exceptions.CommunicationExce ption: Communication exception: java.net.ConnectException: Connection refused: connect
at javapns.communication.ConnectionToAppleServer.getS SLSocket(ConnectionToAppleServer.java:158) ~[firEmergency.jar:na]
at javapns.notification.PushNotificationManager.initi alizeConnection(PushNotificationManager.java:106) ~[firEmergency.jar:na]
at javapns.notification.transmission.NotificationThre ad.runList(NotificationThread.java:215) ~[firEmergency.jar:na]
at javapns.notification.transmission.NotificationThre ad.run(NotificationThread.java:199) ~[firEmergency.jar:na]
at java.lang.Thread.run(Unknown Source) [na:1.6.0_34]
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method) ~[na:1.6.0_34]
at java.net.PlainSocketImpl.doConnect(Unknown Source) ~[na:1.6.0_34]
at java.net.PlainSocketImpl.connectToAddress(Unknown Source) ~[na:1.6.0_34]
at java.net.PlainSocketImpl.connect(Unknown Source) ~[na:1.6.0_34]
at java.net.SocksSocketImpl.connect(Unknown Source) ~[na:1.6.0_34]
at java.net.Socket.connect(Unknown Source) ~[na:1.6.0_34]
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.connect (Unknown Source) ~[na:1.6]
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.<init>( Unknown Source) ~[na:1.6]
at com.sun.net.ssl.internal.ssl.SSLSocketFactoryImpl. createSocket(Unknown Source) ~[na:1.6]
at javapns.communication.ConnectionToAppleServer.getS SLSocket(ConnectionToAppleServer.java:155) ~[firEmergency.jar:na]
... 4 common frames omitted
Hatt jemand einen Tip ?
Gruß Frank
Prowl und aPager (Android ) gehen durch.
Sind bei aPager (iOS) andere Freigaben notwendig?
Ich habe das selbe Problem, welche Ports müssen denn geöffnet sein?
Ebenso die Frage für die emailüberwachung... Port933 und?
Vielen dank
Also ... laut Apple :
"Push providers, iOS devices, and Mac computers are often behind firewalls. To send notifications, you will need to have TCP port 2195 open. To reach the feedback service, you will need to have TCP port 2196 open. Devices and computers connecting to the push service over Wi-Fi will need to have TCP port 5223 open."
Sprich ... der Port 2195 muss von eurem FE Rechner aus offen sein ... damit ihr da raus kommt ....
