Ergebnis 1 bis 6 von 6
Thema: Monitord unter Debian (konkret: wheezy)
    Ich wollte Monitord unter Debian 7 installieren.
    Ich habe jetzt den Source-Code runtergeladen und wollte ihn mit /configure, make und make install installieren.
    configure habe ich mit chmod +x ausführbar gemacht, das scheint auch soweit durchzulaufen.
    Wenn ich jetzt make ausführe, bricht er mit folgendem Fehler ab:
    Code:
    make  all-am
    make[1]: Entering directory `/home/XXXXX/Downloads/trunk'
    g++ -DHAVE_CONFIG_H -I.  -Ijthread-1.2.1/src -D_DEBUG -Wall       -g -O2 -MT monitord/monitord_monitord-MonitorConfiguration.o -MD -MP -MF monitord/.deps/monitord_monitord-MonitorConfiguration.Tpo -c -o monitord/monitord_monitord-MonitorConfiguration.o `test -f 'monitord/MonitorConfiguration.cpp' || echo './'`monitord/MonitorConfiguration.cpp
    In file included from monitord/MonitorConfiguration.cpp:16:0:
    ./simpleopt/SimpleGlob.h: In instantiation of ‘int CSimpleGlobTempl::Add(const SOCHAR*) [with SOCHAR = char]’:
    ./simpleopt/SimpleGlob.h:687:9:   required from ‘int CSimpleGlobTempl::Add(int, const SOCHAR* const*) [with SOCHAR = char]’
    monitord/MonitorConfiguration.cpp:334:62:   required from here
    ./simpleopt/SimpleGlob.h:623:55: error: ‘GetFileTypeS’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
    ./simpleopt/SimpleGlob.h:623:55: note: declarations in dependent base ‘SimpleGlobBase’ are not found by unqualified lookup
    ./simpleopt/SimpleGlob.h:623:55: note: use ‘this->GetFileTypeS’ instead
    ./simpleopt/SimpleGlob.h:644:53: error: ‘FindFirstFileS’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
    ./simpleopt/SimpleGlob.h:644:53: note: declarations in dependent base ‘SimpleGlobBase’ are not found by unqualified lookup
    ./simpleopt/SimpleGlob.h:644:53: note: use ‘this->FindFirstFileS’ instead
    ./simpleopt/SimpleGlob.h:657:9: error: ‘GetFileNameS’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
    ./simpleopt/SimpleGlob.h:657:9: note: declarations in dependent base ‘SimpleGlobBase’ are not found by unqualified lookup
    ./simpleopt/SimpleGlob.h:657:9: note: use ‘this->GetFileNameS’ instead
    ./simpleopt/SimpleGlob.h:657:9: error: ‘IsDirS’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
    ./simpleopt/SimpleGlob.h:657:9: note: use ‘this->IsDirS’ instead
    ./simpleopt/SimpleGlob.h:658:9: error: ‘FindNextFileS’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
    ./simpleopt/SimpleGlob.h:658:9: note: declarations in dependent base ‘SimpleGlobBase’ are not found by unqualified lookup
    ./simpleopt/SimpleGlob.h:658:9: note: use ‘this->FindNextFileS’ instead
    make[1]: *** [monitord/monitord_monitord-MonitorConfiguration.o] Fehler 1
    make[1]: Leaving directory `/home/XXXX/Downloads/trunk'
    make: *** [all] Fehler 2
    Was muss ich tun, damit es klappt?
    Vielen Dank!
    Das Problem liegt wohl in g++-4.7.
    Ich hab das gefunden: http://www.linuxquestions.org/questi...es-4175416791/
    und auf g++4.6 gewechselt, damit lief make durch. Installiert und probiert hab ich noch nicht.
    c.u.
    hemasi
    Hallo Gemeinde,
    jetzt nochmal sehr kompakt zusammengefasst:
    Ich hab hier ein jungfräuliches 64 Bit - Wheezy installiert, allerdings mit Xfce, da mir Gnome und pulseaudio nicht geheuer sind.
    Erstmal alle notwendigen Pakete installieren:
    Code:
    apt-get install build-essential mysql-server mysql-client libmysqlclient-dev subversion autoconf libtool g++-4.6 medit libasound1-dev
    Wie oben schon angedeutet klappt das mit g++-4.7 nicht so richtig, deshalb das folgende script irgendwo speichern:
    Code:
    #!/bin/bash
    rm /usr/bin/cpp
    ln -s /usr/bin/cpp-4.6 /usr/bin/cpp
    echo ln -s cpp-4.6 cpp
    rm /usr/bin/gcc
    ln -s /usr/bin/gcc-4.6 /usr/bin/gcc
    echo ln -s gcc-4.6 gcc
    rm /usr/bin/cc
    ln -s /usr/bin/gcc-4.6 /usr/bin/cc
    echo ln -s gcc-4.6 cc
    rm /usr/bin/g++
    ln -s /usr/bin/g++-4.6 /usr/bin/g++
    echo ln -s g++-4.6 g++
    rm /usr/bin/c++
    ln -s /usr/bin/g++-4.6 /usr/bin/c++
    echo ln -s g++-4.6 c++
    rm /usr/bin/gcov
    ln -s /usr/bin/gcov-4.6 /usr/bin/gcov
    echo ln -s gcov-4.6 gcov
    skript ausführbar machen und starten
    Code:
    chmod a+x skript
    sh skript
    Jetzt der monitor-Teil:
    Code:
    svn co http://svn.monitord.de/monitor/trunk monitord
    cd monitord
    autoreconf -fi
    ./configure --enable-plugins --with-alsa --with-mysql
    make
    make install
    Jetzt noch die monitord.xml kopieren:
    Code:
    cp ./sample-configs/monitord.xml.linux ./monitord/monitord.linux
    und anpassen
    OSS auskommentieren, ALSA einkommentieren und audiorecorder auskommenteren
    HTML-Code:
     <soundcard num="0">
      <!--<device>/dev/dsp0</device>  <!-- OSS: die erste Soundkarte  -->
      <device>plughw:0,0</device> <!-- ALSA: die erste Soundkarte  -->
      <status>1</status> <!-- 1=aktiv, 0=deaktivert -->
      <baud>22050</baud>
      <name> Erste Sondkarte </name>
      <!-- Linker Kanal -->
      <channel part="left">
      <!-- Audio Plugin -->
        <plugin name="audiorecorder">
          <file> monitord/plugins/.libs/libmplugin_audiorecorder.so.0.0.0 </file>
             <parameters>
            <path>    /home/heschmid/recordings/
                </path>
          </parameters>
        </plugin>
    	<name>Kanal 1</name>
    dann muss für sql noch ein kleiner Fehler in der Musterkonfiguration beseitigt werden, da wird wohl im Linux - Musterfile auf eine DLL von Windows verwiesen :-)
    HTML-Code:
    <!-- Daten Plugin -->
     <plugin name="mysql">
    	<file> plugins/.libs/libmplugin_mysql.so.0.0.0</file>
      	<parameters>
      		<logfile> mysql.log </logfile>
    dann muss noch eine Datenbank unter mysql eingerichtet werden und dann kann es mit
    Code:
    /xxxx/monitord/monitord
    losgehen.
    bei mir sieht dass dann mit der DEBUG-Einstellung im Logfile so aus:
    Code:
    10:46:20.671 INFO: monitord/Monitor.cpp(68) monitord restarted - logging with loglevel DEBUG
     10:46:20.671 DEBUG: monitord/MonitorModulesResults.cpp(51) Dispatcher startet
     10:46:20.672 INFO: monitord/Monitor.cpp(113) monitord 2.0svn READY
     10:46:20.673 INFO: monitord/Monitor.cpp(217) starting soundcard #0
     10:46:20.673 INFO: monitord/SndPipe.cpp(152) creating decoders for soundcard #0
     10:46:20.673 INFO: monitord/SndPipe.cpp(156) creating decoder for soundcard #0L:FMS
     10:46:20.673 DEBUG: monitord/MonitorModuleFMS.cpp(100) FMS Parameter
     10:46:20.673 DEBUG: monitord/MonitorModuleFMS.cpp(101) sample : 22050
     10:46:20.673 DEBUG: monitord/MonitorModuleFMS.cpp(102) syncbits: 12
     10:46:20.673 DEBUG: monitord/MonitorModuleFMS.cpp(103) crc    : 1
     10:46:20.673 DEBUG: monitord/MonitorModuleFMS.cpp(104) level  : 0.15259
     10:46:20.673 DEBUG: monitord/MonitorModuleFMS.cpp(105) Algo   : 0
     10:46:20.673 DEBUG: monitord/MonitorModuleFMS.cpp(106) ignW   : 0
     10:46:20.673 DEBUG: monitord/MonitorModuleFMS.cpp(107) ignQ   : 0
     10:46:20.673 DEBUG: monitord/MonitorModuleFMS.cpp(108) ErrC   : 0
     10:46:20.673 DEBUG: monitord/MonitorModuleFMS.cpp(109) force   : 0
     10:46:20.674 INFO: monitord/SndPipe.cpp(178) creating decoder for soundcard #0L:ZVEI
     10:46:20.674 INFO: monitord/SndPipe.cpp(189) creating decoder for soundcard #0R:ZVEI
     10:46:20.674 INFO: monitord/SndPipe.cpp(201) creating decoder for soundcard #0L:POC512
     10:46:20.674 INFO: monitord/MonitorModulePocsag512.cpp(66) (2) sample - crc - ecc - minpreambel - maxerrors - algo:22050 - 1 - 0 - 300 - 10 - 1
     10:46:20.674 INFO: monitord/MonitorModulePocsag512.cpp(79) Algorithmus:1
     10:46:20.674 INFO: monitord/MonitorModulePocsag512.cpp(86) SPHASE_INC is:1521
     10:46:20.674 INFO: monitord/SndPipe.cpp(228) creating decoder for soundcard #0L:POC1200
     10:46:20.674 INFO: monitord/SndPipe.cpp(263) loading audioplugins for left channel
     10:46:20.674 INFO: monitord/SndPipe.cpp(265) loading audioplugins for right channel
     10:46:20.675 INFO: monitord/posix/MonitorAudioALSA.cpp(107) [ALSA] Using pcm_buffer_size=4096 periods=2
     10:46:20.677 INFO: monitord/Monitor.cpp(225) Soundcard #0 started - complete
     10:46:20.678 INFO: monitord/Monitor.cpp(147) monitord socketserver started
     10:46:20.678 DEBUG: monitord/SocketServer.cpp(851) SocketManager erstellt
     10:46:20.679 INFO: monitord/Monitor.cpp(153) fms32pro socketserver started
     10:46:20.680 INFO: monitord/Monitor.cpp(158) crusader socketserver started
     10:46:20.680 INFO: monitord/PluginThread.cpp(326) reading plugin configuration
     10:46:20.680 INFO: monitord/PluginThread.cpp(337) Plugin found: mysql
     10:46:20.680 DEBUG: monitord/PluginThread.cpp(338) File:plugins/.libs/libmplugin_mysql.so.0.0.0
     10:46:20.680 DEBUG: monitord/PluginThread.cpp(341) found parameters
     10:46:20.680 DEBUG: monitord/PluginThread.cpp(16) Erstellt PT:
     10:46:20.680 DEBUG: monitord/PluginThread.cpp(30) DLL Name:plugins/.libs/libmplugin_mysql.so.0.0.0
     10:46:20.681 DEBUG: monitord/PluginThread.cpp(34) done
     10:46:20.682 DEBUG: monitord/plugins/libmplugin_mysql.cpp(231)  reading mapping info
     10:46:20.682 DEBUG: monitord/plugins/libmplugin_mysql.cpp(232) table=monitord_fms
     10:46:20.682 DEBUG: monitord/plugins/libmplugin_mysql.cpp(250) Feld: uhrzeit / mysql:now()
     10:46:20.682 DEBUG: monitord/plugins/libmplugin_mysql.cpp(250) Feld: status / :statusdezimal
     10:46:20.682 DEBUG: monitord/plugins/libmplugin_mysql.cpp(250) Feld: kennung / :fmskennung
     10:46:20.682 DEBUG: monitord/plugins/libmplugin_mysql.cpp(250) Feld: richtung / :richtung
     10:46:20.682 DEBUG: monitord/plugins/libmplugin_mysql.cpp(250) Feld: text / :textuebertragung
     10:46:20.682 DEBUG: monitord/plugins/libmplugin_mysql.cpp(250) Feld: tki / :tki
     10:46:20.682 DEBUG: monitord/plugins/libmplugin_mysql.cpp(250) Feld: quelle / :channelnum
     10:46:20.682 DEBUG: monitord/plugins/libmplugin_mysql.cpp(232) table=monitord_pocsag
     10:46:20.682 DEBUG: monitord/plugins/libmplugin_mysql.cpp(250) Feld: kennung / :ric
     10:46:20.682 DEBUG: monitord/plugins/libmplugin_mysql.cpp(250) Feld: sub / :sub
     10:46:20.682 DEBUG: monitord/plugins/libmplugin_mysql.cpp(232) table=monitord_zvei
     10:46:20.682 DEBUG: monitord/plugins/libmplugin_mysql.cpp(250) Feld: typ / :weckton
     10:46:20.682 DEBUG: monitord/plugins/libmplugin_mysql.cpp(250) Feld: kennung / :zvei
     10:46:20.683 INFO: monitord/plugins/libmplugin_mysql.cpp(191) successfully connected to mysql database monitord on host localhost with username="monitord"
     10:46:20.683 DEBUG: monitord/PluginThread.cpp(304) startet plugin plugins/.libs/libmplugin_mysql.so.0.0.0
     10:46:20.685 INFO: monitord/PluginThread.cpp(79) PluginThread starting
     10:46:20.685 DEBUG: monitord/Monitor.cpp(167) PluginManager started
    nach dem aktivieren der Aufnahme beim Eingangskanal im alsamixer läuft jetzt auch die Auswertung und die Einträge werden in der Datenbank abgelegt.
    Geändert von hemasi (04.01.2013 um 13:01 Uhr)
    Zitat Zitat von hemasi Beitrag anzeigen
    Hallo Gemeinde,
    jetzt nochmal sehr kompakt zusammengefasst: (...)
    spitzenmäßig :)! Danke für das ausführliche Feedback; ich persönlich bin in Sachen monitord nur auf Win32 unterwegs, da ist es MEGA hilfreich, solch detaillierte Hinweise zu bekommen :)!
    Viele Grüße
    Martin
    Wie/Wo genau muss ich denn das Script anlegen?
    Geändert von Keano (12.11.2013 um 22:38 Uhr)
    Wo du das Script anlegst/ausfürhst ist egal.
