Die Logeinträge findest du im Ordner /logs/
Poste doch mal deren Inhalt (Nachdem du versucht hast, dich mit der Oberfläche zu connecten)
Hier das daily.log:
Ich musste es ein wenig einkürzen wegen der Forenregeln.
17:53:47 [INFO] [main] [server.JarFinder][84] Found android.SendMessage
17:53:47 [INFO] [main] [server.JarFinder][84] Found android.Android
17:53:47 [INFO] [main] [server.JarFinder][84] Found anysms.Anysms
17:53:47 [INFO] [main] [server.JarFinder][84] Found anysms.AnysmsTest
17:53:47 [INFO] [main] [server.JarFinder][84] Found batch.Batch
17:53:47 [INFO] [main] [server.JarFinder][84] Found batch.ProcessWatcher
17:53:47 [INFO] [main] [server.JarFinder][84] Found blacklist.BlackList
17:53:47 [INFO] [main] [server.JarFinder][84] Found bosmon_customAlarm.BOSMON_customAlarm
17:53:47 [INFO] [main] [server.JarFinder][84] Found customParams_customAlarm.CustomParams_customAlarm
17:53:47 [INFO] [main] [server.JarFinder][84] Found delay.Delay
17:53:47 [INFO] [main] [server.JarFinder][84] Found exe.ExeCaller
17:53:47 [INFO] [main] [server.JarFinder][84] Found fileReader.FileReader
17:53:47 [INFO] [main] [server.JarFinder][84] Found fms32_customAlarm.FMS32_customAlarm
17:53:47 [INFO] [main] [server.JarFinder][84] Found fmsCrusader_customAlarm.FMSCrusader_customAlarm
17:53:47 [INFO] [main] [server.JarFinder][84] Found calendar.GoogleCalendar
17:53:47 [INFO] [main] [server.JarFinder][84] Found groupalarm.GroupAlarm
17:53:47 [INFO] [main] [server.JarFinder][84] Found ibsystems.IBSystems
17:53:47 [INFO] [main] [server.JarFinder][84] Found null
17:53:47 [INFO] [main] [server.JarFinder][84] Found mail.Mail
17:53:47 [INFO] [main] [server.JarFinder][84] Found mail_expert.MailExpert
17:53:47 [INFO] [main] [server.JarFinder][84] Found tnrConverter.TNRConverter
17:53:47 [INFO] [main] [server.JarFinder][84] Found tnrConverter.CorTest
17:53:47 [INFO] [main] [server.JarFinder][84] Found monitor.Monitor
17:53:47 [INFO] [main] [server.JarFinder][84] Found poc32_customAlarm.POC32_customAlarm
17:53:47 [INFO] [main] [server.JarFinder][84] Found prowl.Prowl
17:53:47 [INFO] [main] [server.JarFinder][84] Found rettalarm.RETTAlarm
17:53:47 [INFO] [main] [server.JarFinder][84] Found rettalarm.GuiPanel
17:53:48 [INFO] [main] [server.JarFinder][84] Found sms77.SMS77
17:53:48 [INFO] [main] [server.JarFinder][84] Found smskaufen.Smskaufen
17:53:48 [INFO] [main] [server.JarFinder][84] Found smstrade.SMSTrade
17:53:48 [INFO] [main] [server.JarFinder][84] Found sound.Sound
17:53:48 [INFO] [main] [server.JarFinder][84] Found textmod.Textmod
17:53:48 [INFO] [main] [server.JarFinder][84] Found timeRules.timeRules
17:53:48 [INFO] [main] [server.JarFinder][84] Found timeRulesEveryXDays.TimeRulesEveryXDays
17:53:48 [INFO] [main] [server.JarFinder][84] Found timeRulesExtended.TimeRulesExtended
17:53:48 [INFO] [main] [server.JarFinder][84] Found weatherrules.Weatherrules.Warnstufe
17:53:48 [INFO] [main] [server.JarFinder][84] Found weatherWarning_customAlarm.WeatherWarning_customAl arm
17:53:48 [INFO] [main] [server.JarFinder][84] Found whitelist.WhiteList
17:53:48 [INFO] [main] [server.JarFinder][84] Found DeepCopy
17:53:48 [INFO] [main] [server.JarFinder][84] Found sockets
17:53:48 [INFO] [main] [server.JarFinder][84] Found AlarmData
17:53:48 [INFO] [main] [server.data.DataManagement][267] File hinzugefügt: C:\Program Files\Alarmierung\firEmergency0.3\Config\Ergste\Er gste.fdb
17:53:48 [INFO] [main] [server.data.DataManagement][267] File hinzugefügt: C:\Program Files\Alarmierung\firEmergency0.3\Config\Admin\Adm in.fdb
17:53:48 [INFO] [main] [server.data.User][241] fdbFile wurde gesetzt: C:\Program Files\Alarmierung\firEmergency0.3\Config\Ergste\Er gste.fdb
17:53:48 [INFO] [main] [server.data.User][241] fdbFile wurde gesetzt: C:\Program Files\Alarmierung\firEmergency0.3\Config\Admin\Adm in.fdb
17:53:48 [INFO] [main] [server.input.InputPool][54] C:\Program Files\Alarmierung\firEmergency0.3\files\inputPlugi ns
17:53:48 [INFO] [main] [server.JarFinder][92] Found AlarmFMS32ExeInput.AlarmFMS32Input
17:53:48 [INFO] [main] [server.JarFinder][92] Found aliveInput.AliveInput
17:53:48 [INFO] [main] [server.JarFinder][92] Found fileInput.FileInput
17:53:48 [INFO] [main] [server.JarFinder][92] Found wetterwarnerInput.WetterInput
17:53:48 [INFO] [main] [server.input.InputPool][101] Objekt für AlarmFMS32Input erzeugt
17:53:48 [INFO] [main] [server.input.InputPool][101] Objekt für AliveInput erzeugt
17:53:48 [INFO] [main] [server.input.InputPool][101] Objekt für FileInput erzeugt
17:53:48 [INFO] [main] [server.input.InputPool][101] Objekt für WetterInput erzeugt
17:53:50 [INFO] [Alarm.exe-Input] [AlarmFMS32ExeInput.AlarmFMS32Input][60] An Port: 5555 gestartet
17:53:54 [INFO] [main] [server.Launcher][127] Launcher fertig
17:53:54 [INFO] [main] [server.Launcher][128] Starten Sie nun die Server-Oberfläche um neue Einsätze angezeigt zu bekommen
18:52:19 [INFO] [main] [server.gui.LauncherServerGUI][29] ServerGUI wird gestarten...
18:52:19 [INFO] [main] [server.gui.LauncherServerGUI][44] Starte LoginScreen...
18:52:33 [WARN] [SwingWorker-pool-1-thread-1] [server.gui.rmi.ssl.InstallCert][76] Zertifikat muss noch akzeptiert werden...
18:52:33 [INFO] [SwingWorker-pool-1-thread-1] [server.gui.login.LoginController$LoginWorker][167] Baue Verbindung auf: EMNOSServer
18:52:33 [INFO] [SwingWorker-pool-1-thread-1] [server.gui.login.LoginController$LoginWorker][171] Starte SSL Verbindung
18:53:15 [INFO] [SwingWorker-pool-1-thread-1] [server.gui.login.LoginController$LoginWorker][187] Verbindung erfolgreich hergestellt
18:53:36 [ERROR] [SwingWorker-pool-1-thread-1] [server.gui.login.LoginController$LoginWorker][214] Fehler beim Verbindungaufbau
java.rmi.ConnectException: Connection refused to host: 169.254.163.226; nested exception is:
java.net.ConnectException: Connection timed out: connect
at sun.rmi.transport.tcp.TCPEndpoint.newSocket(Unknow n Source)
at sun.rmi.transport.tcp.TCPChannel.createConnection( Unknown Source)
at sun.rmi.transport.tcp.TCPChannel.newConnection(Unk nown Source)
at sun.rmi.server.UnicastRef.invoke(Unknown Source)
at java.rmi.server.RemoteObjectInvocationHandler.invo keRemoteMethod(Unknown Source)
at java.rmi.server.RemoteObjectInvocationHandler.invo ke(Unknown Source)
at $Proxy0.login(Unknown Source)
at server.gui.login.LoginController$LoginWorker.doInB ackground(LoginController.java:190)
at server.gui.login.LoginController$LoginWorker.doInB ackground(LoginController.java:1)
at javax.swing.SwingWorker$1.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unkn own Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at javax.swing.SwingWorker.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run Task(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run (Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.net.ConnectException: Connection timed out: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.connect (Unknown Source)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.<init>( Unknown Source)
at com.sun.net.ssl.internal.ssl.SSLSocketFactoryImpl. createSocket(Unknown Source)
at server.gui.rmi.ssl.RMISSLClientSocketFactory.creat eSocket(RMISSLClientSocketFactory.java:54)
... 16 more
ich habe schon eine Idee ... Ich sehe gerade die IP mit der er versucht sich zu verbinden.
"169.254..". Die hat der Rechner aber gar nicht. Das ist diese Adresse, die ein Rechner kurzzeitig besitzt bis er vom DHCP seine Daten erhalten hat. Vielleicht sollte ich da mit fester IP arbeiten?! Aber warum nutzt er diese Adresse?
Sascha
Mach ne feste IP rein und ich denke es läuft dann wieder alles......
mfg Götz
Habe ich getan, scheint alles zu laufen. :-)
Danke, Herr Götz :-)
