Stell mal das LOG-Level auf DEBUG und häng die Logdatei dann mal hier an...
Felix
So das wäre die Logdatei mit Loglevel Debug:
2011-10-08 11:04:22,2, smsd: Smsd v3.1.14 started.
2011-10-08 11:04:22,2, smsd: Running as Sebastian:None.
2011-10-08 11:04:22,7, smsd: Running startup_check (shell): /var/spool/sms/incoming/smsd_script.CwjCNE /tmp/smsd_data.yTEu4B
2011-10-08 11:04:23,7, smsd: Done: startup_check (shell), execution time 1 sec., status: 0 (0)
2011-10-08 11:04:23,4, smsd: File mode creation mask: 022 (0644, rw-r--r--).
2011-10-08 11:04:23,2, smsd: Running in terminal mode.
2011-10-08 11:04:23,5, smsd: Outgoing file checker has started. PID: 2928.
2011-10-08 11:04:23,7, smsd: All PID's: 2928,4356
2011-10-08 11:04:23,5, GSM1: Modem handler 0 has started. PID: 4356.
2011-10-08 11:04:23,3, GSM1: Couldn't open serial port /dev/COM4, error: No such file or directory, waiting 30 sec.
2011-10-08 11:04:24,5, smsd: Moved file /var/spool/sms/outgoing/Test.txt to /var/spool/sms/checked
2011-10-08 11:04:53,3, GSM1: Cannot open serial port /dev/COM4, error: No such file or directory
2011-10-08 11:04:53,2, GSM1: Modem handler 0 terminated. PID: 4356, was started 11-10-08 11:04:23.
2011-10-08 11:04:54,2, smsd: Smsd mainprocess is awaiting the termination of all modem handlers. PID: 2928.
2011-10-08 11:04:54,2, smsd: Smsd mainprocess terminated. PID 2928, was started 11-10-08 11:04:23.
Schreib mal com4 statt COM4, wenn du dir sicher bist, dass es der richtige Port ist...
Felix
Ich könnt kotzen... ;)
Das wars.
Auf der Seite http://smstools3.kekekasvi.com/index.php?p=windows steht ganz unten:
If you like to install smsd (version >= 3.0.3) as a service, then enter this command in a Cygwin Window:
cygrunsrv --install smsd --path /usr/local/bin/smsd.exe --type auto --shutdown --env "CYGWIN=server" --env "PATH=/usr/local/bin:/usr/bin:/bin" --desc "SMS Server Tools 3" --args "-t"
Wenn ich den Befehl eingebe sagt er mir, das er den Befehl cygrunsrv nicht kennt (bash:cygrunsrv:Kommando nicht gefunden)... Weist du an was das liegt?? (wahrscheinlich habe ich ein Paket vergessen zu installieren oder?)
Welches brauche ich dafür und wie kann ich des dann nachträglich noch reininstallieren??
Desweiteren:
Wie kann ich eine SMS an mehrere Empfänger senden?
Wie muss ich das in mein Textdokument schreiben??
Vor jeder Nummer ein "To:" oder einfach untereinander?
Felix
