Ergebnis 1 bis 15 von 91
Thema: SMS-Alarmierung: SMS-Versand über angeschlossenes Handy
    Funktioniert leider beides nicht. Hier der Auszug aus dem log-file:
    2010-01-14 22:40:11,2, smsd: Smsd v3.1.6 started.
    2010-01-14 22:40:11,2, smsd: Running as maex:None.
    2010-01-14 22:40:11,7, smsd: Running startup_check (shell): /tmp/smsd_script.Xpgddk /tmp/smsd_data.1SAYgZ
    2010-01-14 22:40:11,7, smsd: Done: startup_check (shell), execution time 0 sec., status: 0 (0)
    2010-01-14 22:40:11,4, smsd: File mode creation mask: 022 (0644, rw-r--r--).
    2010-01-14 22:40:11,2, smsd: Running in terminal mode.
    2010-01-14 22:40:11,5, smsd: Outgoing file checker has started. PID: 6268.
    2010-01-14 22:40:11,5, GSM14: Modem handler 0 has started. PID: 6632.
    2010-01-14 22:40:11,5, GSM14: Using check_memory_method 1: CPMS is used.
    2010-01-14 22:40:11,3, smsd: FATAL ERROR: Looks like another smsd (6268) is running. I (4888) quit now.
    2010-01-14 22:40:11,2, smsd: Smsd mainprocess terminated abnormally. PID: 4888.
    2010-01-14 22:40:12,6, GSM14: I have to send 1 short message for /var/spool/sms/checked/SMS.txt
    2010-01-14 22:40:12,6, GSM14: Sending SMS from to 49160xx665647
    2010-01-14 22:40:12,6, GSM14: Checking if modem is ready
    2010-01-14 22:40:12,7, GSM14: -> AT
    2010-01-14 22:40:12,7, GSM14: Command is sent, waiting for the answer
    2010-01-14 22:40:12,7, GSM14: <- OK
    2010-01-14 22:40:12,6, GSM14: Pre-initializing modem
    2010-01-14 22:40:13,7, GSM14: -> ATE0+CMEE=1
    2010-01-14 22:40:13,7, GSM14: Command is sent, waiting for the answer
    2010-01-14 22:40:13,7, GSM14: <- OK
    2010-01-14 22:40:13,6, GSM14: Checking if modem needs PIN
    2010-01-14 22:40:13,7, GSM14: -> AT+CPIN?
    2010-01-14 22:40:14,7, GSM14: <- +CPIN: SIM PIN OK
    2010-01-14 22:40:14,5, GSM14: Modem needs PIN, but it's not defined for this modem
    2010-01-14 22:40:14,2, GSM14: PIN handling: expected READY, modem answered +CPIN: SIM PIN OK
    2010-01-14 22:40:14,2, GSM14: Modem handler 0 terminated abnormally. PID: 6632.
    2010-01-14 22:40:22,5, smsd: Moved file /var/spool/sms/outgoing/SMS.txt to /var/spool/sms/checked
    Felix
    Auf der Seite ist ist ja seine smsd.conf zu sehen, dort hat er ja eine Pin definert, oder.
    Hast du die smsd.conf nochmal geändert oder ist die Pin nicht richtig ? Schalt die Pin doch einfach aus und setz den Pin auf Ignore....
    Wenn es die nicht zu Riskant ist.
    Klappt bei mir hier wunderbar. Noch ein Tipp, wenn das nachher läuft, kannst du smsd als Windows Dienst mitstarten. So brauchst du CYGWIN nicht immer laufen zu haben, klappt Eina-A ;-)
    Dr.M
    Ich hatte bei der Pindefinition ein "#" vor der Zeile. Das war das Problem.
    Nun funktioniert der Versand! :)
    Jetzt fehlt nur noch die Anbindung an FMS32. Der Versand sollte natürlich so schnell wie möglich erfolgen. Wie baue ich das ganze am besten auf? Über eine Batch-Datei oder lieber eine Alternative?
    Wie funktioniert das mit dem Windows-Dienst?
    Vielen Dank für eure Hilfe!!!
    Also ich habe das hier mit einer Patch gelöst, sieht in etwa so aus :
    @Echo To: 49171234567890 >>sms
    @Echo. >>sms
    @Echo SMS Alarm mit Meldung : %* >>sms
    in einer weiteren datei habe ich folgendes gemacht (kannst du auch in einer Batch machen)
    call sms.bat %* (die datei von oben)
    copy sms c:\cygwin\var\spool\sms\outgoing
    del sms
    @ECHO Batch SMS gestartet am %date% um %time% >>sendlog
    Die letzte Zeile ist für mich als art log gedacht.
    Das ganze rufe ich dann unter Empfänger -> Aktion mit senden1.bat %3 aus.
    Mit dem als Dienst starten findest du eine Befehelszeile auf der Seite von SMSTools, dort unter Windows oder wie das heisst. Diese Zeile tippst du einmal in CYGWIN ein und dann ist der Dienst schon installiert.
    Aber, du brauchst dazu cygrunsrv, hast du wahrscheinlich nicht Installiert. Findest du bei der Installation, glaube ich unter Admin.
    Viel Erfolg
    Ok, das hat funktioniert. Kann ich auch gleich mehrere Emfänger in der SMS-Datei angeben oder muss ich für jeden Empfänger eine eigene Datei anlegen und diese dann kopieren?
    Ich habe für jeden Empfänger eine eigene Datei gemacht,
    gibt aber diverese möglichkeiten. Habe auch was gelesen von Mehre Empfänger auf einmal als Script. Hab mich aber damit noch nicht beschäftigt.
    Muss mal sehen ob es noch andere möglichkeiten gibt, bin da auch noch am Forschen
    Gruss
