Ergebnis 1 bis 10 von 10
Thema: Tetra (BosDigitalfunk) online scanner live !
    tetrascanner Gast
    The Dutch police (The Netherlands) have temporarely
    connected there new digital Tetra system to there old
    analog system (crosslink)
    The network is called C2000 wich is the similar to the
    UK Airwave network
    This is a unique chance to listen to a digital Tetra network
    just as if you would have a working Tetra radio like the police do.
    There is an online scanner (24/7) wich is now streaming this audio to the internet
    The scanner also scans some old analog channels...so you hear a mix of both...when it's Tetra you can hear the typical "plup" at the end of each transmission.
    Very rarely you hear a "mishap" when signals get decoded wrongly
    Also you may hear a strong "howl" sometimes wich is caused by the fact that police are still carrying around there old analog portables as a back up...this sometimes causes feedback.
    The online scanner is receiving 2 different analog channels at 86 Mhz wich are linked to 2 different talkgroups from the Tetra network.
    The police dispatch center is located in Haarlem close to Amsterdam
    The link may stay alive for a few weeks and then dissappear
    forever...chances to ever hear decoded Tetra again are very minimal because other countries either don't allow online scanners or they simply don't link there new tetra network with the older analog network.
    A link to this online scanner at my website:
    www.tetrascanner.com (digital online scanners)
    Offcourse they do speak Dutch ...sorry :)
    Greetings
    Tetrascanner
    The Netherlands
    Das ganze mal in Deutsch:)
    Die holländische Polizei (die Niederlande) hat temporarely dort neues digitales Tetra- System an dort altes analoges System (Querverbindung) angeschlossen Das Netz wird C2000 genannt, den wich zum BRITISCHEN Airwavenetz das ähnliche ist Dieses ist eine einzigartige Wahrscheinlichkeit, zu einem digitalen Tetra- Netz zu hören, gerade als ob Sie einen Funktion Tetra- Radio haben würden, wie die Polizei. Es gibt ein on-line-Scanner (24/7) wich strömt jetzt dieser Audio zum Internet, das der Scanner auch einige alte analoge Führungen... ablichtet, also hören Sie eine Mischung von beiden..., wenn Tetra- it's Sie das typische "plup" hören kann; am Ende jedes Getriebes. Sehr selten hören Sie ein "mishap" wenn Signale falsch auch decodiert erhalten, Sie können ein starkes "howl" hören; manchmal wird wich durch die Tatsache verursacht, das tragen noch um dort alte analoge portables polizeilich überwachen, während ein Unterstützungs... dieses manchmal Rückgespräch verursacht. Der on-line-Scanner empfängt 2 unterschiedliche analoge Führungen bei 86 MHZ wich werden verbunden mit 2 unterschiedlichen talkgroups vom Tetra- Netz. Die Polizeiabfertigung Mitte ist in Haarlem nah an Amsterdam Die Verbindung kann für einige Wochen lebendig bleiben und dann sind dissappear für immer... Wahrscheinlichkeiten, decodiertes Tetra- überhaupt zu hören wieder sehr minimal, weil andere Länder jedes don't on-line-Scanner oder sie einfach don't Verbindung dort neues Tetra- Netz mit dem älteren Analognetz erlauben.
    Christian Gast
    Die holländische Polizei hat für eine Übergangszeit ihr neues, digitales Tetra-System an das vorhandene alte analoge System mittels einer Querverbindung angeschlossen. Das Netz wird C2000 genannt, welches zum britischen Airwave-Netz ähnlich ist.
    Dies ist eine einzigartige Möglichkeit ein digitales Tetra- Netz hineinzuhören, fast so als ob Sie ein Tetrafunkgerät hätten, wie die Polizei. Es gibt ein Online-Scanner (24/7) welcher seine Daten als Audiostream ins Internet bringt. Es kann vorkommen, dass der Scanner auch einige rein analoge Funksprüche umsetzt. Sie hören eine Mischung von beiden Funkarten.
    Wenn es Tetra ist, hören Sie das typische "plup" am Ende jeder
    Übertragung. Sehr selten hören Sie ein "mishap" wenn die Signale falsch decodiert werden. Sie können ein starkes "howl" hören; manchmal wird passiert dies aufgrund der Tatsache, das die Polizei noch alte analoge Handfunkgeräte als Rückfallebene nutzt, die manchmal Rückkopplungen verursachen.
    Der Online-Scanner empfängt 2 unterschiedliche analoge Frequenzen bei 86 MHz welche mit den mit 2 unterschiedlichen Benutzergruppen vom Tetra- Netz verbunden werden.
    Die Polizeiabfertigung Mitte ist in Haarlem nah bei Amsterdam. Die Verbindung wird wohl nür für wenige Wochen bestehen und dann für immer abgeschaltet werden. Die Wahrscheinlichkeiten decodiertes Tetra überhaupt zu hören wird sehr gering sein, weil einige Länder keine Online-Scanner erlauben oder sie einfach ihr neues Tetra- Netz nicht mit dem älteren Analognetz verbinden.
    Is ja doll.
    Das kann man aber im Aachener Tetra-Gebiet schon lange, aber ohne Online-Scanner.
    Das einzige was hier verschwunden ist, sind die Funkabwicklungen über 2m der Polizei und der gesamte Sprechfunkverkehr des BGS im Raum Aachen.
    Und noch was, diese Umwandlung ins Analoge wird nicht abgeschaltet, weil..........aber Ihr wißt ja warum..........2006 und so, ha, ha, ha.....
    Aber eine gute Sache hat die Abschaltung der holländischen Analog-Frequenzen: endlich verschwinden die aus dem 4m-Band. Die liegen nämlich im Oberband teilweise dicht an vor Ort benutzten BOS-Kanälen und stören.
    FunkerVogth
    Und jetzt Werbung:
    http://www.ig-wasi.de/
    Das Forum zur Seite:
    http://forum.ig-wasi.de/
    www.hochleistungssirene.de
    Re: Das ganze mal in Deutsch:)
    Original geschrieben von Hauptlöschmeister
    Blabla
    Also, mal eine kleine Anmerkung - diese automatischen Babelfisch-Übersetzungen kann man sich auch sparen, das ist ja wohl nicht wirklich hilfreich, das hier abzukippen. Dann kann man es ja im englischen Original noch besser verstehen ...
    mfg lars
    Ja dann mach das doch !!
    Was machen?
    mfg lars
    Lauschi Gast
    Auf Englisch lesen und verstehen ;-)
    Techman Gast
    tot...
    ist mittlerweile nun nicht mehr zu erreichen.
    sollte man also mal löschen :-)
    hättest du den Thread nicht wieder rausgeholt wäre er schon längst tot.
    Ist ja auch schon über 3 Jahre her.
