Bogerfunk hat nichts was andere schon haben.
Habe eine Email nach Bogerfunk geschickt.
Frage nach Umbaukosten für DISC.
Oder was heißt der nachvolgende Text :
There is no standard discriminator output on the AR1500 /E/EX models. However it is possible to obtain discriminator (detector) output by wiring directly to the NFM discriminator chip, this is IC 3 MC3372 pin 9 located on the i.f. PCB (the larger SMD chip on the underside of the board, pin 1 is marked with a dot/circle - count pin numbers anti-clockwise).
A suitable ground may be taken from almost and point close to whatever socket you mount on the unit to provide a durable connection or use pin 15 on IC3 MC3372.
Depending upon the loading of your external circuit, you may need to buffed the connection to the discriminator with a capacitor, resistor or both (otherwise it may result in little or no audio output from the receiver).
Einen Schaltplan besitze ich von www.Mosk.com
Uwitron
