Thema: Motorola Tetra SDS - TSI oder SSI
    ich habe ein Problem beim Versenden von SDS mit einem Motorola.
    Die SDS soll in eine Gruppe. Bei der Abfrage der Gruppen wird deren
    langer Identifier geliefert (TSI). Beim Versenden mit der TSI kriege ich
    aber einen Fehler CME: Error 34 und Error 35. Mit der SSI klappt es.
    Frage: Gibt es eine Möglichkeit zu ermitteln, ob die TSI oder die SSI
    beim Versenden angegeben werden muss?
    Besten Dank
    FE
    Laut ETSI TS 100 392-5:
    In V+D mode the set syntax is:
    +CTSDS=<AI service>, <called party identity type>, [<area>], [<access priority>], [<end to end encryption>]
    NOTE:
    The <end to end encryption> parameter is included for future expansion.
    In DMO mode the set syntax is:
    +CTSDS=<AI service>, <called party identity type>, [<area>], [<priority level>], [<end to end encryption>],
    [<comms type>], [<importance factor>]
    CTSDS read syntax
    +CTSDS?
    The read command returns the read result code text as defined in clause 6.14.6.5.
    6.14.6.5
    CTSDS read result code text
    In V+D mode the read result code text is:
    +CTSDS: <AI service>, <called party identity type>, [<area>], [<access priority>], [<end to end encryption>]
    In DMO mode the read result code text is:
    +CTSDS: <AI service>, <called party identity type>, [<area>], [<priority level>], [<end to end encryption>],
    6.17.11 Called party identity type
    This parameter is used to indicate the type of identity to be used as the called party address. The associated identity used
    in signalling will be interpreted differently according to this parameter. External subscriber number addresses are used
    in association with a PSTN or PABX gateway.
    • 0 - SSI;
    • 1 - TSI;
    • 2 - SNA (V+D only);
    • 3 - PABX external subscriber number (V+D or DMO if via a gateway);
    • 4 - PSTN external subscriber number (V+D or DMO if via a gateway);
    NOTE:
    The actual value of the gateway identities (PSTN, PABX) is provisioned in the MT and cannot be
    changed over the PEI by AT commands.
    5 - Extended TSI.
    Vielen Dank!
    Da hatte ich wohl Tomaten auf den Augen.
    FE
