Ok, dann ist der in der Version nicht drin.
Starte mal mit -v und poste das Ergebnis
Gesendet von meinem D5803 mit Tapatalk
No RICs, no fun.
SW Version: 2.0
Build Date: 2015/07/13
Frequency: 172.xxxM
Device-ID: 0
Error in PPM: 0
Active Demods: 1
- POC1200
Squelch: 0
Verbose Mode!
03.11.2016 19:15:58 - boswatch [DEBUG ] reading config file
03.11.2016 19:15:58 - boswatch [DEBUG ] - BOSWatch:
03.11.2016 19:15:58 - boswatch [DEBUG ] -- loglevel = 10
03.11.2016 19:15:58 - boswatch [DEBUG ] -- backupcount = 7
03.11.2016 19:15:58 - boswatch [DEBUG ] -- useregexfilter = 0
03.11.2016 19:15:58 - boswatch [DEBUG ] -- doublefilter_ignore_entries = 10
03.11.2016 19:15:58 - boswatch [DEBUG ] -- doublefilter_ignore_time = 5
03.11.2016 19:15:58 - boswatch [DEBUG ] -- doublefilter_check_msg = 0
03.11.2016 19:15:58 - boswatch [DEBUG ] - FMS:
03.11.2016 19:15:58 - boswatch [DEBUG ] -- iddescribed = 0
03.11.2016 19:15:58 - boswatch [DEBUG ] - ZVEI:
03.11.2016 19:15:58 - boswatch [DEBUG ] - POC:
03.11.2016 19:15:58 - boswatch [DEBUG ] -- allow_ric =
03.11.2016 19:15:58 - boswatch [DEBUG ] -- deny_ric =
03.11.2016 19:15:58 - boswatch [DEBUG ] -- filter_range_start = 0000000
03.11.2016 19:15:58 - boswatch [DEBUG ] -- filter_range_end = 9999999
03.11.2016 19:15:58 - boswatch [DEBUG ] set loglevel of fileHandler to: 10
03.11.2016 19:15:58 - boswatch [DEBUG ] set backupCount of fileHandler to: 7
03.11.2016 19:15:58 - pluginLoader [DEBUG ] loading plugins
03.11.2016 19:15:58 - pluginLoader [DEBUG ] Search in plugin folder
03.11.2016 19:15:58 - pluginLoader [DEBUG ] Plugin [ENABLED ] BosMon
03.11.2016 19:15:58 - pluginLoader [DEBUG ] Plugin [DISABLED] eMail
03.11.2016 19:15:58 - pluginLoader [DEBUG ] Plugin [DISABLED] jsonSocket
03.11.2016 19:15:58 - pluginLoader [DEBUG ] Plugin [DISABLED] template
03.11.2016 19:15:58 - pluginLoader [DEBUG ] Plugin [DISABLED] firEmergency
03.11.2016 19:15:58 - pluginLoader [DEBUG ] Plugin [ENABLED ] MySQL
03.11.2016 19:15:58 - pluginLoader [DEBUG ] Plugin [ENABLED ] httpRequest
03.11.2016 19:15:58 - pluginLoader [DEBUG ] load plugin: BosMon
03.11.2016 19:15:58 - pluginLoader [DEBUG ] call BosMon.onLoad()
03.11.2016 19:15:58 - pluginLoader [DEBUG ] load plugin: MySQL
03.11.2016 19:15:58 - pluginLoader [DEBUG ] call MySQL.onLoad()
03.11.2016 19:15:58 - pluginLoader [DEBUG ] load plugin: httpRequest
03.11.2016 19:15:58 - pluginLoader [DEBUG ] call httpRequest.onLoad()
03.11.2016 19:15:58 - boswatch [DEBUG ] starting rtl_fm
03.11.2016 19:16:01 - boswatch [DEBUG ] starting multimon-ng
03.11.2016 19:16:04 - boswatch [DEBUG ] start decoding
sieht nach einer Funktion aus..
