Ergebnis 1 bis 7 von 7
Thema: Mailplugin Could not convert sockert to TLS
    bekomme folgende Fehlermeldung beim Mailversand über das Mailplugin:
    [qoute]Mail -- Could not convert socket to TLS[/quote]
    Java Version: v8 Update 40
    Ist das Problem bekannt? Wie kann ich das fixen?
    Java Update auf v8 Update 45 hat nicht gebracht...
    Auszug aus dem Aktuellen Log File:
    08.05.2015 - 20:08:24.555 ERROR Launcher - Email konnte nicht versandt werden: Could not convert socket to TLS
    javax.mail.MessagingException: Could not convert socket to TLS
    at com.sun.mail.smtp.SMTPTransport.startTLS(SMTPTrans port.java:1907) ~[firEmergency.jar:na]
    at com.sun.mail.smtp.SMTPTransport.protocolConnect(SM TPTransport.java:666) ~[firEmergency.jar:na]
    at javax.mail.Service.connect(Service.java:295) ~[firEmergency.jar:na]
    at javax.mail.Service.connect(Service.java:176) ~[firEmergency.jar:na]
    at server.surveillance.SendMail.sendMail(SendMail.jav a:123) ~[firEmergency.jar:na]
    at server.Launcher$1.run(Launcher.java:361) ~[firEmergency.jar:na]
    at java.lang.Thread.run(Unknown Source) [na:1.8.0_45]
    Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderE xception: unable to find valid certification path to requested target
    at sun.security.ssl.Alerts.getSSLException(Unknown Source) ~[na:1.8.0_45]
    at sun.security.ssl.SSLSocketImpl.fatal(Unknown Source) ~[na:1.8.0_45]
    at sun.security.ssl.Handshaker.fatalSE(Unknown Source) ~[na:1.8.0_45]
    at sun.security.ssl.ClientHandshaker.serverCertificat e(Unknown Source) ~[na:1.8.0_45]
    at sun.security.ssl.ClientHandshaker.processMessage(U nknown Source) ~[na:1.8.0_45]
    at sun.security.ssl.Handshaker.processLoop(Unknown Source) ~[na:1.8.0_45]
    at sun.security.ssl.Handshaker.process_record(Unknown Source) ~[na:1.8.0_45]
    at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source) ~[na:1.8.0_45]
    at sun.security.ssl.SSLSocketImpl.performInitialHands hake(Unknown Source) ~[na:1.8.0_45]
    at sun.security.ssl.SSLSocketImpl.startHandshake(Unkn own Source) ~[na:1.8.0_45]
    at com.sun.mail.util.SocketFetcher.configureSSLSocket (SocketFetcher.java:549) ~[firEmergency.jar:na]
    at com.sun.mail.util.SocketFetcher.startTLS(SocketFet cher.java:486) ~[firEmergency.jar:na]
    at com.sun.mail.smtp.SMTPTransport.startTLS(SMTPTrans port.java:1902) ~[firEmergency.jar:na]
    ... 6 common frames omitted
    Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderE xception: unable to find valid certification path to requested target
    at sun.security.validator.PKIXValidator.doBuild(Unkno wn Source) ~[na:1.8.0_45]
    at sun.security.validator.PKIXValidator.engineValidat e(Unknown Source) ~[na:1.8.0_45]
    at sun.security.validator.Validator.validate(Unknown Source) ~[na:1.8.0_45]
    at sun.security.ssl.X509TrustManagerImpl.validate(Unk nown Source) ~[na:1.8.0_45]
    at sun.security.ssl.X509TrustManagerImpl.checkTrusted (Unknown Source) ~[na:1.8.0_45]
    at sun.security.ssl.X509TrustManagerImpl.checkServerT rusted(Unknown Source) ~[na:1.8.0_45]
    ... 17 common frames omitted
    Caused by: sun.security.provider.certpath.SunCertPathBuilderE xception: unable to find valid certification path to requested target
    at sun.security.provider.certpath.SunCertPathBuilder. build(Unknown Source) ~[na:1.8.0_45]
    at sun.security.provider.certpath.SunCertPathBuilder. engineBuild(Unknown Source) ~[na:1.8.0_45]
    at java.security.cert.CertPathBuilder.build(Unknown Source) ~[na:1.8.0_45]
    ... 23 common frames omitted
    08.05.2015 - 20:08:24.844 ERROR Throwable - javax.mail.MessagingException: Could not convert socket to TLS;
    nested exception is:
    08.05.2015 - 20:08:24.880 ERROR Throwable - at com.sun.mail.smtp.SMTPTransport.startTLS(SMTPTrans port.java:1907)
    08.05.2015 - 20:08:24.896 ERROR Throwable - at com.sun.mail.smtp.SMTPTransport.protocolConnect(SM TPTransport.java:666)
    08.05.2015 - 20:08:24.909 ERROR Throwable - at javax.mail.Service.connect(Service.java:295)
    08.05.2015 - 20:08:24.917 ERROR Throwable - at javax.mail.Service.connect(Service.java:176)
    08.05.2015 - 20:08:24.938 ERROR Throwable - at server.surveillance.SendMail.sendMail(SendMail.jav a:123)
    08.05.2015 - 20:08:24.946 ERROR Throwable - at server.Launcher$1.run(Launcher.java:361)
    08.05.2015 - 20:08:24.951 ERROR Throwable - at java.lang.Thread.run(Unknown Source)
    08.05.2015 - 20:08:24.960 ERROR Throwable - Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderE xception: unable to find valid certification path to requested target
    08.05.2015 - 20:08:24.978 ERROR Throwable - at sun.security.ssl.Alerts.getSSLException(Unknown Source)
    08.05.2015 - 20:08:24.988 ERROR Throwable - at sun.security.ssl.SSLSocketImpl.fatal(Unknown Source)
    08.05.2015 - 20:08:24.998 ERROR Throwable - at sun.security.ssl.Handshaker.fatalSE(Unknown Source)
    08.05.2015 - 20:08:25.010 ERROR Throwable - at sun.security.ssl.Handshaker.fatalSE(Unknown Source)
    08.05.2015 - 20:08:25.018 ERROR Throwable - at sun.security.ssl.ClientHandshaker.serverCertificat e(Unknown Source)
    08.05.2015 - 20:08:25.029 ERROR Throwable - at sun.security.ssl.ClientHandshaker.processMessage(U nknown Source)
    08.05.2015 - 20:08:25.040 ERROR Throwable - at sun.security.ssl.Handshaker.processLoop(Unknown Source)
    08.05.2015 - 20:08:25.047 ERROR Throwable - at sun.security.ssl.Handshaker.process_record(Unknown Source)
    08.05.2015 - 20:08:25.062 ERROR Throwable - at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source)
    08.05.2015 - 20:08:25.069 ERROR Throwable - at sun.security.ssl.SSLSocketImpl.performInitialHands hake(Unknown Source)
    08.05.2015 - 20:08:25.077 ERROR Throwable - at sun.security.ssl.SSLSocketImpl.startHandshake(Unkn own Source)
    08.05.2015 - 20:08:25.088 ERROR Throwable - at sun.security.ssl.SSLSocketImpl.startHandshake(Unkn own Source)
    08.05.2015 - 20:08:25.096 ERROR Throwable - at com.sun.mail.util.SocketFetcher.configureSSLSocket (SocketFetcher.java:549)
    08.05.2015 - 20:08:25.101 ERROR Throwable - at com.sun.mail.util.SocketFetcher.startTLS(SocketFet cher.java:486)
    08.05.2015 - 20:08:25.111 ERROR Throwable - at com.sun.mail.smtp.SMTPTransport.startTLS(SMTPTrans port.java:1902)
    08.05.2015 - 20:08:25.120 ERROR Throwable - ... 6 more
    08.05.2015 - 20:08:25.133 ERROR Throwable - Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderE xception: unable to find valid certification path to requested target
    08.05.2015 - 20:08:25.146 ERROR Throwable - at sun.security.validator.PKIXValidator.doBuild(Unkno wn Source)
    08.05.2015 - 20:08:25.155 ERROR Throwable - at sun.security.validator.PKIXValidator.engineValidat e(Unknown Source)
    08.05.2015 - 20:08:25.162 ERROR Throwable - at sun.security.validator.Validator.validate(Unknown Source)
    08.05.2015 - 20:08:25.169 ERROR Throwable - at sun.security.ssl.X509TrustManagerImpl.validate(Unk nown Source)
    08.05.2015 - 20:08:25.178 ERROR Throwable - at sun.security.ssl.X509TrustManagerImpl.checkTrusted (Unknown Source)
    08.05.2015 - 20:08:25.186 ERROR Throwable - at sun.security.ssl.X509TrustManagerImpl.checkServerT rusted(Unknown Source)
    08.05.2015 - 20:08:25.194 ERROR Throwable - ... 17 more
    08.05.2015 - 20:08:25.202 ERROR Throwable - Caused by: sun.security.provider.certpath.SunCertPathBuilderE xception: unable to find valid certification path to requested target
    08.05.2015 - 20:08:25.221 ERROR Throwable - at sun.security.provider.certpath.SunCertPathBuilder. build(Unknown Source)
    08.05.2015 - 20:08:25.235 ERROR Throwable - at sun.security.provider.certpath.SunCertPathBuilder. engineBuild(Unknown Source)
    08.05.2015 - 20:08:25.241 ERROR Throwable - at java.security.cert.CertPathBuilder.build(Unknown Source)
    08.05.2015 - 20:08:25.274 ERROR Throwable - ... 23 more
    Geändert von bilarful (08.05.2015 um 20:13 Uhr)
    Kannst du Java 7 testen?
    Es gibt seit Java 8 vermehrt Probleme mit Zertifikaten (was auch dein Fehler ist).
    Java akzeptiert die SSL/TSL-Zertifikate nicht (unable to find valid certification path to requested target), wodurch keine Verbindung aufgebaut werden kann.
    Habe Java 8 deinstalliert und die "neuste" Version von Java 7.
    Gleiches Problem besteht immer noch..
    In der aktuellen Beta kann man im Input Plug-in einstellen, dass alle Zertifikate akzeptiert werden sollen.
    Das löst das Problem.
    Damit könntest dies versuchen.
    Danke für die Antwort!
    Wie komme ich denn an die Beta? Im Shop habe ich keinen Bereich mit Beta Versionen gefunden..
    Edit: Link gefunden, werde mal testen
    Geändert von bilarful (18.05.2015 um 09:18 Uhr)
    Wo kann ich das im PlugIn einstellen?
