Noch mal ein Feedback an dieser Stelle:
Das mit dem neu runterladen etc. hat nichts gebracht.
Der AM3 hängt sich nach wie vor auf. Aufgrund der Fehlermeldungen tippe ich auf ein Problem mit Google Maps.
Code:
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2015-04-16 21:39:31.423
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:62)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:888)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:869)
at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:390)
at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:143)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:76)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:107)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:70)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:175)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.clearContext(PartRenderingEngine.java:974)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:954)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$3(PartRenderingEngine.java:862)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$8.run(PartRenderingEngine.java:857)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.removeGui(PartRenderingEngine.java:841)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.disposeWidget(ElementReferenceRenderer.java:118)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:933)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:894)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2015-04-16 21:39:31.428
!MESSAGE Exception occurred while unrendering: org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl@16688fe (elementId: de.alamos.monitor.view.googlemaps.view, tags: [View, categoryTag:Karte], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (contributionURI: bundleclass://org.eclipse.ui.workbench/org.eclipse.ui.internal.e4.compatibility.CompatibilityView, object: null, context: null, variables: [], label: Google Maps, iconURI: platform:/plugin/de.alamos.monitor.view.googlemaps/icons/maps.png, tooltip: null, dirty: false, closeable: true, description: null)
!STACK 0
Heute hat es sich wie folgt verhalten:
- Der Bildschirmschoner hat sich nicht beendet (was er normalerweise tut)
- Während des Alarms gab es im Log keine Auffälligkeiten
- Als ich anschließend noch einmal per VNC auf den AM3 PC geschaut habe, ist der AM wieder eingefroren.
