Ergebnis 1 bis 6 von 6
Thema: AM3 Anzeige Rückmeldungen
    Wenn ich im AM3 die Page:
    " Tools --> Einstellungen --> Rückmeldungen --> Personen "
    öffnen will kommt folgende Störung / Meldung
    eclipse.buildId=unknown
    java.version=1.7.0_09
    java.vendor=Oracle Corporation
    BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
    Command-line arguments: -os win32 -ws win32 -arch x86
    Error
    Mon Dec 29 13:49:47 CET 2014
    Problems occurred when invoking code from plug-in: "org.eclipse.jface".
    java.lang.NoClassDefFoundError: de/alamos/monitor/view/feedback/pref/FeedbackPersonPreferencesPage$TreeContentProvider
    at de.alamos.monitor.view.feedback.pref.FeedbackPerso nPreferencesPage.createTreeView(FeedbackPersonPref erencesPage.java:258)
    at de.alamos.monitor.view.feedback.pref.FeedbackPerso nPreferencesPage.createFieldEditors(FeedbackPerson PreferencesPage.java:86)
    at org.eclipse.jface.preference.FieldEditorPreference Page.createContents(FieldEditorPreferencePage.java :227)
    at org.eclipse.jface.preference.PreferencePage.create Control(PreferencePage.java:232)
    at org.eclipse.jface.preference.PreferenceDialog.crea tePageControl(PreferenceDialog.java:1502)
    at org.eclipse.jface.preference.PreferenceDialog$14.r un(PreferenceDialog.java:1259)
    at org.eclipse.core.runtime.SafeRunner.run(SafeRunner .java:42)
    at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil. java:49)
    at org.eclipse.jface.util.SafeRunnable.run(SafeRunnab le.java:175)
    at org.eclipse.jface.preference.PreferenceDialog.show Page(PreferenceDialog.java:1253)
    at org.eclipse.ui.internal.dialogs.FilteredPreference Dialog.showPage(FilteredPreferenceDialog.java:675)
    at org.eclipse.jface.preference.PreferenceDialog$10.r un(PreferenceDialog.java:709)
    at org.eclipse.swt.custom.BusyIndicator.showWhile(Bus yIndicator.java:70)
    at org.eclipse.jface.preference.PreferenceDialog$9.se lectionChanged(PreferenceDialog.java:705)
    at org.eclipse.jface.viewers.StructuredViewer$3.run(S tructuredViewer.java:888)
    at org.eclipse.jface.viewers.StructuredViewer.firePos tSelectionChanged(StructuredViewer.java:886)
    at org.eclipse.jface.viewers.StructuredViewer.handleP ostSelect(StructuredViewer.java:1226)
    at org.eclipse.jface.viewers.StructuredViewer$5.widge tSelected(StructuredViewer.java:1251)
    at org.eclipse.jface.util.OpenStrategy.firePostSelect ionEvent(OpenStrategy.java:262)
    at org.eclipse.jface.util.OpenStrategy.access$5(OpenS trategy.java:256)
    at org.eclipse.jface.util.OpenStrategy$3.run(OpenStra tegy.java:433)
    at org.eclipse.swt.widgets.RunnableLock.run(RunnableL ock.java:35)
    at org.eclipse.swt.widgets.Synchronizer.runAsyncMessa ges(Synchronizer.java:135)
    at org.eclipse.swt.widgets.Display.runAsyncMessages(D isplay.java:4145)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Di splay.java:3762)
    at org.eclipse.jface.window.Window.runEventLoop(Windo w.java:826)
    at org.eclipse.jface.window.Window.open(Window.java:8 02)
    at org.eclipse.ui.internal.dialogs.WorkbenchPreferenc eDialog.open(WorkbenchPreferenceDialog.java:215)
    at org.eclipse.ui.internal.OpenPreferencesAction.run( OpenPreferencesAction.java:65)
    at org.eclipse.jface.action.Action.runWithEvent(Actio n.java:499)
    at org.eclipse.jface.action.ActionContributionItem.ha ndleWidgetSelection(ActionContributionItem.java:58 4)
    at org.eclipse.jface.action.ActionContributionItem.ac cess$2(ActionContributionItem.java:501)
    at org.eclipse.jface.action.ActionContributionItem$5. handleEvent(ActionContributionItem.java:411)
    at org.eclipse.swt.widgets.EventTable.sendEvent(Event Table.java:84)
    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.ja va:1057)
    at org.eclipse.swt.widgets.Display.runDeferredEvents( Display.java:4170)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Di splay.java:3759)
    at org.eclipse.e4.ui.internal.workbench.swt.PartRende ringEngine$9.run(PartRenderingEngine.java:1113)
    at org.eclipse.core.databinding.observable.Realm.runW ithDefault(Realm.java:332)
    at org.eclipse.e4.ui.internal.workbench.swt.PartRende ringEngine.run(PartRenderingEngine.java:997)
    at org.eclipse.e4.ui.internal.workbench.E4Workbench.c reateAndRunUI(E4Workbench.java:138)
    at org.eclipse.ui.internal.Workbench$5.run(Workbench. java:610)
    at org.eclipse.ui.internal.Workbench.createAndRunWork bench(Workbench.java:567)
    at org.eclipse.ui.PlatformUI.createAndRunWorkbench(Pl atformUI.java:150)
    at de.alamos.monitor.application.Application.start(Ap plication.java:24)
    at org.eclipse.equinox.internal.app.EclipseAppHandle. run(EclipseAppHandle.java:196)
    at org.eclipse.core.runtime.internal.adaptor.EclipseA ppLauncher.runApplication(EclipseAppLauncher.java: 110)
    at org.eclipse.core.runtime.internal.adaptor.EclipseA ppLauncher.start(EclipseAppLauncher.java:79)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.ru n(EclipseStarter.java:354)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.ru n(EclipseStarter.java:181)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Nativ e Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknow n Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Un known Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at org.eclipse.equinox.launcher.Main.invokeFramework( Main.java:636)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.ja va:591)
    at org.eclipse.equinox.launcher.Main.run(Main.java:14 50)
    | Server: ML110G7 | RAID5 | 12GB | ESXi5.5U2
    | FE-Server: Ubuntu12.04 LTS (on ESXi)
    | AM3-Client: Windows 2008 R2 (on ESXi)
    ich kann damit nichts Anfangen aber wenn da ein Fehler kommt würde ich fast behaupten wollen das dann ein generelles Problem ist!
    Konnte das Problem lösen.
    Lösung:
    AM3 neu downloaden und das Plugin Verzeichnis auf die alte Installation kopieren.
    Danach konnten die Kameraden unter Rückmeldungen erfolgreich eingepflegt werden.
    Anscheinend ist da mal was hops gegangen. :)
    Rückmeldung funktioniert jetzt und die restlichen Einstellungen sind aus der alten Installation erhalten geblieben.
    Trotzdem herzlichen Danke für die Rückmeldungen.
