Hallo...
ist das hier "nur" ein Java Problem:
28.10.2013 - 10:14:31.685 ERROR SmackConfiguration - Error! A startup class specified in smack-config.xml could not be loaded: org.jivesoftware.smackx.ServiceDiscoveryManager
28.10.2013 - 10:14:31.685 ERROR SmackConfiguration - Error! A startup class specified in smack-config.xml could not be loaded: org.jivesoftware.smackx.XHTMLManager
28.10.2013 - 10:14:31.685 ERROR SmackConfiguration - Error! A startup class specified in smack-config.xml could not be loaded: org.jivesoftware.smackx.muc.MultiUserChat
28.10.2013 - 10:14:31.685 ERROR SmackConfiguration - Error! A startup class specified in smack-config.xml could not be loaded: org.jivesoftware.smackx.bytestreams.ibb.InBandByte streamManager
28.10.2013 - 10:14:31.700 ERROR SmackConfiguration - Error! A startup class specified in smack-config.xml could not be loaded: org.jivesoftware.smackx.bytestreams.socks5.Socks5B ytestreamManager
28.10.2013 - 10:14:31.700 ERROR SmackConfiguration - Error! A startup class specified in smack-config.xml could not be loaded: org.jivesoftware.smackx.filetransfer.FileTransferM anager
28.10.2013 - 10:14:31.700 ERROR SmackConfiguration - Error! A startup class specified in smack-config.xml could not be loaded: org.jivesoftware.smackx.LastActivityManager
28.10.2013 - 10:14:31.716 ERROR SmackConfiguration - Error! A startup class specified in smack-config.xml could not be loaded: org.jivesoftware.smackx.commands.AdHocCommandManag er
28.10.2013 - 10:14:31.716 ERROR SmackConfiguration - Error! A startup class specified in smack-config.xml could not be loaded: org.jivesoftware.smackx.ServiceDiscoveryManager
28.10.2013 - 10:14:31.732 ERROR SmackConfiguration - Error! A startup class specified in smack-config.xml could not be loaded: org.jivesoftware.smackx.XHTMLManager
28.10.2013 - 10:14:31.732 ERROR SmackConfiguration - Error! A startup class specified in smack-config.xml could not be loaded: org.jivesoftware.smackx.muc.MultiUserChat
28.10.2013 - 10:14:31.732 ERROR SmackConfiguration - Error! A startup class specified in smack-config.xml could not be loaded: org.jivesoftware.smackx.bytestreams.ibb.InBandByte streamManager
28.10.2013 - 10:14:31.747 ERROR SmackConfiguration - Error! A startup class specified in smack-config.xml could not be loaded: org.jivesoftware.smackx.bytestreams.socks5.Socks5B ytestreamManager
28.10.2013 - 10:14:31.747 ERROR SmackConfiguration - Error! A startup class specified in smack-config.xml could not be loaded: org.jivesoftware.smackx.filetransfer.FileTransferM anager
28.10.2013 - 10:14:31.747 ERROR SmackConfiguration - Error! A startup class specified in smack-config.xml could not be loaded: org.jivesoftware.smackx.LastActivityManager
28.10.2013 - 10:14:31.747 ERROR SmackConfiguration - Error! A startup class specified in smack-config.xml could not be loaded: org.jivesoftware.smackx.commands.AdHocCommandManag er
Welche FE Version? Direkt bei Start von FE? Oder erst bei Abarbeitung eines Alarms? Du nutzt das xmpp Plugin?
Gesendet via Mobile App
Gibt es eine maximale Anzahl von Straßen im Straßenverzeichnis?
Danke MM
in der Wetteranzeige wird selbst Nachts strahlender Sonnenschein angezeigt.
Ist das so gewolt ?
Neues Problem:
Wir haben festgestellt das sich bei uns der Firemergency Server ab und an einfach am PC schließt und wir das erst ein weilchen später über die Lebenszeichen-Mail dies mitbekommen.
Woran könnte es liegen ?
ist es möglich mit einer Einheit mehrere andere Einheiten anderer Benutzer mit zu alarmieren?
Sodas wenn Einheit A von Admin alarmiert wird auch Einheit B von Benutzer B und Einheit C von Benutzer C mit alarmiert werden.
Grund hierfür ist die Adressverwaltung. So müsste ich nicht die Adressen von Benutzer B und Benutzer C auch im Benutzer Admin pflegen.
Christopher
Bei uns in der FW soll der AM3 in Verbindung mit FE eingeführt werden....
Ich wurde von meinem Kommandant mit der Installation und Einrichtung des System beauftragt. Die Software wurde von Ihm über den Shop gekauft. Nun hat er mir zur Installation die Seriennummern für FE Basic und das AM3 Plugin weiter gereicht. Jedoch ist nun mein Problem der Download von FE und des Plugin.
Gibt es eine Möglichkeit die FE Basic Version und das AM3 Plugin zu downloaden und erst anschließend mit Hilfe der Seriennummer zu aktivieren/registrieren?
Mein Problem aktuell ist, dass er sich zum Kauf im Shop einen eigenen Account eingerichtet hat und ich ja nun sein Passwort benötigen würde um die Software herunter zu laden.
Registriere dich selber auch ;) Du kannst die Versionen dann runterladen, denn in der Community Version, ist fE kostenlos. Nach erfolgreicher Aktivierung hast du dann die Basic Version ;)
Vielen Dank!!
Geändert von Firefighter38 (01.11.2013 um 12:02 Uhr)
Aktive Benutzer in diesem Thema: 40 (Registrierte Benutzer: 0, Gäste: 40)
