first excuse if my english is not the best...
You are right there are two pagers which would be able to do this. The Boss910MK and the Boss925MK, but this Pagers are still in the construction. They should be available at the end of the Year. But there are some restrictions...
The Boss910MK should be able to receive 2 Channels and the Boss925MK should be able to receive 9 channels.
But the Pagers have a tuning frequency. This frequency is in the band (4m(81-88MHz), 2m(138-174MHz), 70cm(400-470MHz)) and the Pager can only receive on a channel with + or - 300kHz of the tuning frequency.
For example: tuning frequency: 149.200 MHz
range: 148.900 MHz - 149.500 MHz
Then there is another restriction. You are asking for receiving at the same time. Thats not possible...
The pager has a PLL. So the frequencys can be programmed. The pager is toggling between the programmed frequencys.
If it noticed an alarm it will stop toggling and will start decoding. After an alarm it will start toggling again.
So the alarms can't be exact at the same time, but it is possible to reseive at two frequencys...
It may be possible that you can give a priority for one channel...
But that I doesn't know...
I hope I helped you a little bit...
with best regards friend112
