Ergebnis 1 bis 4 von 4
Thema: installation !?
    feuerfresser99 Gast
    installation !?
    hallo leute !
    ich nutze knoppix mit 2.6er Kernel und bekomme immer folgende meldung :
    root@ttyp0[mon]# make
    mkdir bin-i686
    gcc -Wstrict-prototypes -I/usr/X11R6/include -O3 -march=i486 -DARCH_I386 -c -o bin-i686/hdlc.o hdlc.c
    gcc -Wstrict-prototypes -I/usr/X11R6/include -O3 -march=i486 -DARCH_I386 -c -o bin-i686/pocsag.o pocsag.c
    pocsag.c: In function `delete_EOF_errors':
    pocsag.c:312: Warnung: deprecated use of label at end of compound statement
    gcc -Wstrict-prototypes -I/usr/X11R6/include -O3 -march=i486 -DARCH_I386 -c -o bin-i686/translate.o translate.c
    gcc -Wstrict-prototypes -I/usr/X11R6/include -O3 -march=i486 -DARCH_I386 -c -o bin-i686/demod_afsk12.o demod_afsk12.c
    gcc -Wstrict-prototypes -I/usr/X11R6/include -O3 -march=i486 -DARCH_I386 -c -o bin-i686/demod_afsk24.o demod_afsk24.c
    gcc -Wstrict-prototypes -I/usr/X11R6/include -O3 -march=i486 -DARCH_I386 -c -o bin-i686/demod_afsk24_2.o demod_afsk24_2.c
    gcc -Wstrict-prototypes -I/usr/X11R6/include -O3 -march=i486 -DARCH_I386 -c -o bin-i686/demod_hapn48.o demod_hapn48.c
    gcc -Wstrict-prototypes -I/usr/X11R6/include -O3 -march=i486 -DARCH_I386 -c -o bin-i686/demod_fsk96.o demod_fsk96.c
    gcc -Wstrict-prototypes -I/usr/X11R6/include -O3 -march=i486 -DARCH_I386 -c -o bin-i686/fms.o fms.c
    gcc -Wstrict-prototypes -I/usr/X11R6/include -O3 -march=i486 -DARCH_I386 -c -o bin-i686/demod_poc5.o demod_poc5.c
    gcc -Wstrict-prototypes -I/usr/X11R6/include -O3 -march=i486 -DARCH_I386 -c -o bin-i686/demod_poc12.o demod_poc12.c
    gcc -Wstrict-prototypes -I/usr/X11R6/include -O3 -march=i486 -DARCH_I386 -c -o bin-i686/demod_poc24.o demod_poc24.c
    gcc -Wstrict-prototypes -I/usr/X11R6/include -O3 -march=i486 -DARCH_I386 -c -o bin-i686/demod_fms.o demod_fms.c
    gcc -Wstrict-prototypes -I/usr/X11R6/include -O3 -march=i486 -DARCH_I386 -c -o bin-i686/demod_dtmf.o demod_dtmf.c
    gcc -Wstrict-prototypes -I/usr/X11R6/include -O3 -march=i486 -DARCH_I386 -c -o bin-i686/demod_zvei.o demod_zvei.c
    gcc -Wstrict-prototypes -I/usr/X11R6/include -O3 -march=i486 -DARCH_I386 -c -o bin-i686/unixinout.o unixinout.c
    gcc -Wstrict-prototypes -I/usr/X11R6/include -O3 -march=i486 -DARCH_I386 -c -o bin-i686/monitor_rou.o monitor_rou.c
    gcc -Wstrict-prototypes -I/usr/X11R6/include -O3 -march=i486 -DARCH_I386 -c -o bin-i686/mkcostab.o mkcostab.c
    gcc bin-i686/mkcostab.o -lm -lncurses -lX11 -L/usr/X11R6/lib -o bin-i686/mkcostab
    /usr/bin/ld: cannot find -lX11
    collect2: ld returned 1 exit status
    make: *** [bin-i686/mkcostab] Fehler 1
    und nach make install :
    make install
    Installiere Monitor und Gen nach /usr/local/bin,
    Manual nach /usr/local/man/mann
    als Super User
    su -c"/usr/bin/install -c monitor /usr/local/bin;\
    /usr/bin/install -c bin-i686/gen /usr/local/bin;\
    /usr/bin/install -c monrc.n.gz /usr/local/man/mann"
    /usr/bin/install: Aufruf von stat für ,,monitor" nicht möglich: Datei oder Verzeichnis nicht gefunden
    /usr/bin/install: Aufruf von stat für ,,bin-i686/gen" nicht möglich: Datei oder Verzeichnis nicht gefunden
    /usr/bin/install: reguläre Datei ,,/usr/local/man/mann" kann nicht angelegt werden: Das Dateisystem ist nur lesbar
    make: *** [install] Fehler 1
    was mach ich falsch ?!
    Fabian
    Re: installation !?
    Original geschrieben von feuerfresser99
    hallo leute !
    Fabian
    Hi Fabian,
    der GCC findet die libX11 nicht. Das will er dir zumindest mit der Fehlermeldung sagen. Wenn Du auf das "Scope" als Anzeigegerät verzichten kann, entferne die Zeilen, die X11 erfordern. Einen entsprechenden Patch hatte ich mal gepostet. Ebenso gibt's noch ne Anleitung im Klartext.
    feuerfresser99 Gast
    aja..danke soweit !
    aber worauf bitte soll ich verzichten ?!
    (bin linux newbie) starte knoppix auch
    nur von cd...kann es sein das er deswegen
    irgendwie nicht schreiben kann ?! habe
    sonst nur NTFS Partitionen...dann müsste ich
    warten bis der Raid controller da ist... =(
    Fabian
    ich habs mal installiert, weis jetzt aber nicht mehr, wie das war
    aber in einer der readmes stand es genau geschrieben, wie du den monitor ohne das scope modul installieren
    gruss KW
