Tetra (BosDigitalfunk) online scanner live !
The Dutch police (The Netherlands) have temporarely
connected there new digital Tetra system to there old
analog system (crosslink)
The network is called C2000 wich is the similar to the
UK Airwave network
This is a unique chance to listen to a digital Tetra network
just as if you would have a working Tetra radio like the police do.
There is an online scanner (24/7) wich is now streaming this audio to the internet
The scanner also scans some old analog channels...so you hear a mix of both...when it's Tetra you can hear the typical "plup" at the end of each transmission.
Very rarely you hear a "mishap" when signals get decoded wrongly
Also you may hear a strong "howl" sometimes wich is caused by the fact that police are still carrying around there old analog portables as a back up...this sometimes causes feedback.
The online scanner is receiving 2 different analog channels at 86 Mhz wich are linked to 2 different talkgroups from the Tetra network.
The police dispatch center is located in Haarlem close to Amsterdam
The link may stay alive for a few weeks and then dissappear
forever...chances to ever hear decoded Tetra again are very minimal because other countries either don't allow online scanners or they simply don't link there new tetra network with the older analog network.
A link to this online scanner at my website:
www.tetrascanner.com (digital online scanners)
Offcourse they do speak Dutch ...sorry :)
Greetings
Tetrascanner
The Netherlands
Das ganze mal in Deutsch:)
Die holländische Polizei (die Niederlande) hat temporarely dort neues digitales Tetra- System an dort altes analoges System (Querverbindung) angeschlossen Das Netz wird C2000 genannt, den wich zum BRITISCHEN Airwavenetz das ähnliche ist Dieses ist eine einzigartige Wahrscheinlichkeit, zu einem digitalen Tetra- Netz zu hören, gerade als ob Sie einen Funktion Tetra- Radio haben würden, wie die Polizei. Es gibt ein on-line-Scanner (24/7) wich strömt jetzt dieser Audio zum Internet, das der Scanner auch einige alte analoge Führungen... ablichtet, also hören Sie eine Mischung von beiden..., wenn Tetra- it's Sie das typische "plup" hören kann; am Ende jedes Getriebes. Sehr selten hören Sie ein "mishap" wenn Signale falsch auch decodiert erhalten, Sie können ein starkes "howl" hören; manchmal wird wich durch die Tatsache verursacht, das tragen noch um dort alte analoge portables polizeilich überwachen, während ein Unterstützungs... dieses manchmal Rückgespräch verursacht. Der on-line-Scanner empfängt 2 unterschiedliche analoge Führungen bei 86 MHZ wich werden verbunden mit 2 unterschiedlichen talkgroups vom Tetra- Netz. Die Polizeiabfertigung Mitte ist in Haarlem nah an Amsterdam Die Verbindung kann für einige Wochen lebendig bleiben und dann sind dissappear für immer... Wahrscheinlichkeiten, decodiertes Tetra- überhaupt zu hören wieder sehr minimal, weil andere Länder jedes don't on-line-Scanner oder sie einfach don't Verbindung dort neues Tetra- Netz mit dem älteren Analognetz erlauben.
Re: Das ganze mal in Deutsch:)
Original geschrieben von Hauptlöschmeister
Blabla
Also, mal eine kleine Anmerkung - diese automatischen Babelfisch-Übersetzungen kann man sich auch sparen, das ist ja wohl nicht wirklich hilfreich, das hier abzukippen. Dann kann man es ja im englischen Original noch besser verstehen ...
mfg lars
