Seit 2 Stunden ca. kommt es bei dem Versuch eine Mail über das System zu versenden zu folgendem Fehler und Log Eintrag:
21:47:40.171 ERROR MailExpert - Could not connect to SMTP host: smtp.gmail.com, port: 465, response: -1
javax.mail.MessagingException: Could not connect to SMTP host: smtp.gmail.com, port: 465, response: -1
at com.sun.mail.smtp.SMTPTransport.openServer(SMTPTra nsport.java:1949) ~[firEmergency.jar:na]
at com.sun.mail.smtp.SMTPTransport.protocolConnect(SM TPTransport.java:654) ~[firEmergency.jar:na]
at javax.mail.Service.connect(Service.java:295) ~[firEmergency.jar:na]
at javax.mail.Service.connect(Service.java:176) ~[firEmergency.jar:na]
at mail_expert.MailExpert.run(MailExpert.java:226) ~[plugin_mail_expert.jar:na]
at server.PluginController.run(PluginController.java: 95) [firEmergency.jar:na]
at java.lang.Thread.run(Unknown Source) [na:1.7.0_71]
21.12.2014 - 21:47:40.187 ERROR PluginController - Fehler im Plugin! Mail Expert (Admin1) Message: (Could not connect to SMTP host: smtp.gmail.com, port: 465, response: -1)
at server.PluginController.run(PluginController.java: 95) ~[firEmergency.jar:na]
21.12.2014 - 21:47:40.187 ERROR SystemLogHandler - javax.mail.MessagingException: Could not connect to SMTP host: smtp.gmail.com, port: 465, response: -1
21.12.2014 - 21:47:40.187 ERROR SystemLogHandler - at com.sun.mail.smtp.SMTPTransport.openServer(SMTPTra nsport.java:1949)
21.12.2014 - 21:47:40.187 ERROR SystemLogHandler - at com.sun.mail.smtp.SMTPTransport.protocolConnect(SM TPTransport.java:654)
21.12.2014 - 21:47:40.187 ERROR SystemLogHandler - at javax.mail.Service.connect(Service.java:295)
21.12.2014 - 21:47:40.187 ERROR SystemLogHandler - at javax.mail.Service.connect(Service.java:176)
21.12.2014 - 21:47:40.187 ERROR SystemLogHandler - at mail_expert.MailExpert.run(MailExpert.java:226)
21.12.2014 - 21:47:40.187 ERROR SystemLogHandler - at server.PluginController.run(PluginController.java: 95)
21.12.2014 - 21:47:40.187 ERROR SystemLogHandler - at java.lang.Thread.run(Unknown Source)
21.12.2014 - 21:47:40.187 INFO PluginController - PluginController mit Plugin mail_expert.MailExpert (Admin1) mit AlarmData () nach 600562 ms beendet
Die Werte im Plugin stimmen zu 100% und wurden auch nicht geändert. Per Telnet ist der SMTP Server vom PC( Auf dem auch der Server läuft) aus erreichbar und lässt sich anwählen.
Wir können das Ganze insbesondere deshalb nicht nachvollziehen, weil das selbe Problem bereits vorgestern aufgetreten ist, sich dort dann aber ohne jegliche Aktion unsererseits im wahrsten Sinne des Wortes über Nacht gelöst hat.
Gibt es da von euch irgendwelche Ideen oder Lösungsvorschläge?
