Ich habe da eine vbs lösung gefunden welche alle möglichen dateien aus einem bestimmten ordner mit versenden kann.
diese vbs datei läuft ohne Blat.exe, Clemail.exe usw..
HIER DER CODE DER DATEI
Set ws = CreateObject("WScript.Shell")
Dim FS, DS, File, Pfad, Anhang, ENachricht, NachRicht
Const cdoSendUsingPickup = 1
Const cdoSendUsingPort = 2
Const cdoAnonymous = 0
Const cdoBasic = 1
Const cdoNTLM = 2
' SEND MAIL
Pfad = "D:\emailalarm\test\"
if Pfad = "" then
AuS
else
'nix
end if
Set objMessage = CreateObject("CDO.Message")
objMessage.Subject = "AlarmFax"
objMessage.From = """AlarmFax"" Ausgang eMail>"
objMessage.To = "Eingang eMail"
objMessage.TextBody = "AlarmFax"
'Dateien
Set FS = CreateObject("Scripting.FileSystemObject")
If FS.FolderExists (Pfad)=True Then
'msgbox "Ordner ist da!",vbinformation,"Ordner da!"
Set DS = FS.GetFolder(Pfad)
for Each File in DS.Files
Anhang = File.Name
objMessage.AddAttachment Pfad & Anhang
next
Set DS = Nothing
Set FS = Nothing
else
msgbox "Ordner ist nicht da!",vbinformation,"Ordner nicht da!"
set FS = nothing
end if
'Konfiguration SMTP Server
objMessage.Configuration.Fields.Item _
("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
("http://schemas.microsoft.com/cdo/configuration/smtpserver") = "mail.gmx.net"
'Type of authentication, NONE, Basic (Base64 encoded), NTLM
("http://schemas.microsoft.com/cdo/configuration/smtpauthenticate") = cdoBasic
'Your UserID on the SMTP server
("http://schemas.microsoft.com/cdo/configuration/sendusername") = "Ausgang eMail"
'Your password on the SMTP server
("http://schemas.microsoft.com/cdo/configuration/sendpassword") = "PASSWORT"
'Server port (typically 25)
("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = 25
'Use SSL for the connection (False or True)
("http://schemas.microsoft.com/cdo/configuration/smtpusessl") = False
'Connection Timeout in seconds (the maximum time CDO will try to establish a connection to the SMTP server)
("http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout") = 60
objMessage.Configuration.Fields.Update
objMessage.Send
Set objMessage = Nothing
AuS
Private Sub AuS
WScript.Quit
End Sub
