Probleme beim starten unter Linux (X11)
ich versuche den crusader unter suse linux 9.2 zu starten. Es kommt aber folgender Fehler:
localhost cm/crusader> java -jar FMSCrusaderV4-30Demo.jar -CS
Exception in thread "main" java.lang.InternalError: Can't connect to X11 window server using ':0.0' as thevalue of the DISPLAY variable.
at sun.awt.X11GraphicsEnvironment.initDisplay(Native Method)
at sun.awt.X11GraphicsEnvironment.<clinit>(X11Graphic sEnvironment.java:134)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:141)
at java.awt.GraphicsEnvironment.getLocalGraphicsEnvir onment(GraphicsEnvironment.java:62)
at java.awt.Window.init(Window.java:231)
at java.awt.Window.<init>(Window.java:275)
at java.awt.Frame.<init>(Frame.java:401)
at java.awt.Frame.<init>(Frame.java:366)
at javax.swing.JFrame.<init>(JFrame.java:154)
at FMSCrusader.<init>(FMSCrusader.java:45)
at FMSCrusader.main(FMSCrusader.java:282)
Kann mir jemand helfen????
chris
